Felpro or gm head gaskets
Old Mar 2, 2003 | 08:38 PM
INFERNO's Avatar
What head gaskets should I go with, Fel-pro or Gm? Any fel-pro gasket recommended more than the Gm? I am rebuilding the motor so I need all of them.
Old Mar 2, 2003 | 08:56 PM
Josh-'04 GTO's Avatar
I used all GM in my stroker. I'm sure some have used Felpro with success, but I'd rather take my chances with the GM ones.
Old Mar 2, 2003 | 10:01 PM
96z's Avatar
96z
Im going with felpro for my stroker mainly for the gasket thickness I need to get my compression ratio right...I dont think you could really go wrong with either...
Old Mar 2, 2003 | 10:03 PM
Dr.Mudge's Avatar
I like FelPro better, but have used GM gaskets (Impy) with no problems.
Old Mar 2, 2003 | 10:27 PM
CODY BEHNKE's Avatar
Alot of GM gaskets are made by Fel-Pro
Old Mar 2, 2003 | 10:48 PM
wantafastz28's Avatar
Felpro
Old Mar 2, 2003 | 11:29 PM
DjArcadian's Avatar
Felpro are better and stronger. If you're going to go GM get the Impalla gasket everyone talks about. Better quench and slllllightly better compression.
Old Mar 2, 2003 | 11:46 PM
Fatdog's Avatar
Cool
Felpro.When my intake was fixed,my mechanic used Felpro.Fixed.My02
Old Mar 3, 2003 | 01:29 AM
Vader's Avatar
I had to make the same decision a while back. And the reason was that I had the heads off because the GM head gasket failed. I went with Felpro - cheaper and better. Easy choice.
Old Mar 3, 2003 | 07:17 AM
Smoke T/A's Avatar
Felpro
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
