Im going with felpro for my stroker mainly for the gasket thickness I need to get my compression ratio right...I dont think you could really go wrong with either...
Felpro are better and stronger. If you're going to go GM get the Impalla gasket everyone talks about. Better quench and slllllightly better compression.
I had to make the same decision a while back. And the reason was that I had the heads off because the GM head gasket failed. I went with Felpro - cheaper and better. Easy choice.
