Fastest Bolt on LT1?
Old Apr 7, 2007 | 02:54 PM
  #16
hsyr's Avatar
I remember a guy on here (can't remember screen name) was running high 12's at like 112mph with a full weight bolton M6 car. I will see if i can find who it was.
Old Apr 7, 2007 | 04:03 PM
  #17
danhr's Avatar
there is a lot of people running high 12's with bolt on cars. I ran a 8.1 in mine, and I still have more "bolting-on" to do.
Old Apr 7, 2007 | 06:21 PM
  #18
94_firechicken's Avatar
turbos, superchargers, cams, heads, 12 bolt/9 inch, are also considered bolt ons. and I've seen some hitting 9's. I want a list on what's considered bolt ons and what isn't, it's very ambigious. If you are talking about the most you can get out of the car without increasing the CI then there are also 8's out there.
Old Apr 7, 2007 | 11:09 PM
  #19
Z28Dreamer's Avatar
IMO
BoltOn = NA, any bolt on part WITHOUT getting inside the motor.
Old Apr 8, 2007 | 12:52 AM
  #20
j0n's Avatar
j0n
i went 12.700 @ 107.96 in a 3620lb convertible with longtubes, aluminum ds, subframe connectors, tubular lcas, re-loc brackets, 4.10s in a 10-bolt, shifter, k&n cai, and madz28 tuned.
Drove it an hour and a half to the track, ran without changes, and drove another hour and a half directly to work for an 8-hour shift, and finally home(another 20min).
edit: that pass was at +310 DA...with some 1.6 rockers, an electric water pump, a torque arm, some better driving, and some better weather(my buddy got some -1xxx DA a few weeks later at the same track) I have no doubt the car would have gone low 12s
Old Apr 8, 2007 | 01:02 AM
  #21
roadtrip120's Avatar
12.295 @ 112mph ,here
1.76 60' 700ft DA
Full bolt-on
Stereo, A/C, PWS, All Seat, Carpet, drag wheels
No; ft sway bar, spare tire and jack
Old Apr 8, 2007 | 02:56 PM
  #22
Jamon's Avatar
That definitely classifies 9 inch as a bolt on then...and that's one of the best, but most expensive, bolt ons you can drop in a car.
Old Apr 8, 2007 | 02:58 PM
  #23
Z28Dreamer's Avatar
Ya think thats gonna make your car faster go ahead then bolt it in
Old Apr 8, 2007 | 03:05 PM
  #24
bombebomb's Avatar
I knew someone was gonna say it rofl.
The term bolt ons is highly debateable, some people consider N20 a bolt on, others do not, some consider turbos/superchargers bolt ons some do not.
IMO if a turbo or a super charger is "bolt on" then you could make 1 pass with a car running rediculously high boost and go into the 8's, of course the car would die at the end of the track, but it was just "bolt ons" same goes for N20. But to all there own.
Old Apr 8, 2007 | 03:27 PM
  #25
bombebomb's Avatar
What are not bolt ons? pistons and cranks?
Originally Posted by Z28Roxy
If you consider nitrous or boost a bolt on, I think a better question is what don't you consider a bolt on.
that is a good question lol, im not sure why people consider "some" stuff bolt ons.
Old Apr 8, 2007 | 03:37 PM
  #26
STREETLETHALZ's Avatar
shon herron
www.herronperformance.com
look under shop car.
he's also pretty much the cheapest for alot of parts. he's a sponsor here too.
i think he ran 11.80 in his bolton LT1. w3rd.
Old Apr 16, 2007 | 09:08 PM
  #27
Shon Herron's Avatar
Originally Posted by slomarao
A stock lt1 would never run 11's unless you had it down to around 2300lbs. Which is impossible, why are you so concerned with a stock trim car?
Car was 3100ish with 230ish driver.
The key is making use of every HP that the motor would put out. solid everything and good air on the best track around (carolina dragway).
Even with the carpet, and interior panels I am pretty sure it would still run in the 11.8s, considering it had never been tuned with a WBO2, just tuned by feel
Someone else try to get the LT1 Bolt on down to 11.7s, I know it will do it!!!
Old Apr 16, 2007 | 11:09 PM
  #28
j0n's Avatar
j0n
if i hadn't bought my iroc i would be doing just that right now...i can only imagine starting off with a lighter car than my vert and doing all bolt-ons...
Old Apr 17, 2007 | 12:53 AM
  #29
CamaroRacing12's Avatar
we bow down to u shon herron lol
Old Apr 17, 2007 | 07:42 AM
  #30
chrism400's Avatar
You forgot to add the fact that you must know how to drive. I'd say 1 out of 10 drivers really know how to launch a 6 speed right.
