fans will not turn on when car is running
Old Aug 12, 2008 | 10:30 AM
93camarochrisz28's Avatar
ok i can jump the b,a on the aldl plug and fans turn on but when i the car is just running the fans will not come on and will start to over heat ? i really dont know what to do i
Old Aug 20, 2008 | 12:07 AM
BCdawg57's Avatar
I have the same problem.
Old Aug 20, 2008 | 12:19 AM
The PCM turns the fans on based on the temperature readings from the coolant temp sensor in the water pump housing. Check the sensor to see if it is accurate (courtesy of Shoebox):
http://shbox.com/1/4th_gen_tech2.html#ect
Stock programming turns the first fan on at 226*F (or low speed mid-94 and up) and the second fan (or high speed mid-94 and up) at 235*F. Is it getting that hot?
Do the fans run when you turn the A/C on?
Red97LT1
9
Dec 17, 2014 06:13 PM
NewsBot
Dec 3, 2014 12:30 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
