Fans on way too early
Old Apr 2, 2006 | 07:12 PM
Camaro91RS's Avatar
Unhappy Fans on way too early
Hey guys,
My problem began a couple weeks ago. I changed the stock t-stat to a hypertech 160*, new coolant, and did a throttle body bypass. I started driving the car in mid march, so the weather was still really cold at night. At first, the car would normally operate between 160-170. The fan would kick in around 200-210, which seemed normal. Now, the fan will kick on within 2-3 minutes of starting the car (usually the gauge is at 120-130 when it begins). I'm thinking that the few days I drove it in very cold temperatures threw the pcm off. Is there a way to reset the fans to stock? or maybe I have a different problem?
ps - I tried disconnecting the negative battery cable, no luck.
Any help would be greatly appreciated
Old Apr 2, 2006 | 08:09 PM
sabre81's Avatar
Re: Fans on way too early
Sounds like you have other issues. The car isn't thwoing any codes is it? no SES light? Usually when you change to a 160* t-stat, you need to program the fans to come on earlier. This is strange.
Old Apr 2, 2006 | 09:59 PM
SnakeOiler's Avatar
You probably forgot to hook up some connector (IAT, MAF, etc). Check all of your wiring
Old Apr 3, 2006 | 06:49 PM
Camaro91RS's Avatar
replaced the coolant temp sensor, no luck
then realized the AIR connector was loose, all seems well now...thanks for everything guys
real quick though, while searching for blown fuses, I noticed this:
http://img.photobucket.com/albums/v3...samfusebox.jpg
is something supposed to go there? lol
Old Apr 3, 2006 | 09:40 PM
sabre81's Avatar
i don't remember off hand... check the underside of the fusebox cover, it will tell you.
Old Apr 3, 2006 | 11:28 PM
Camaro91RS's Avatar
found out it stays empty, thanks though
so on my way home just now I noticed my fan was still kicking on before 160! godddd whatever, i'm out of ideas so I guess I'll just leave it for now
Old Apr 4, 2006 | 08:33 AM
Camaro91RS's Avatar
ok nevermind I can't leave it..i'm obsessed with my car as most of you can understand lol. the thing that confuses me is that I haven't had a single SES code and the idle seems perfect. It's the stock chip I'm 99% sure, and all fuses look fine. Shoebox? anybody?
Old Apr 4, 2006 | 08:41 AM
Did you check for any codes?
Old Apr 4, 2006 | 02:53 PM
Camaro91RS's Avatar
Thanks for the quick reply, u the man
I took it to auto zone to see if it would scan any codes. of course, their scanner was broken but they said if there hasn't been a SES light going on, it most likely won't show anything anyways.
One thing I did notice was, if I turn the heat off, they operate normally. Even on the 2 middle vent settings they are fine. But when it's on the 2 right side heat settings, the fans turn on immediately. Hmm?
Old Apr 4, 2006 | 02:59 PM
WS Sick's Avatar
Are both fans on or just one?
Old Apr 4, 2006 | 03:04 PM
sabre81's Avatar
Dumb question, but when your key is in the 'On' position with the car off, does your SES light, light up? :d
Just checking. Mine died before.
Old Apr 4, 2006 | 03:10 PM
Camaro91RS's Avatar
Just the drivers side, it's full blast too.
Not sure if there's any correlation, but the ac (front of pulley?) will turn for about 4 seconds, then stop for 20, start for 4, etc. while fan is on.
thanks, I appreciate the help.
Old Apr 4, 2006 | 03:12 PM
Camaro91RS's Avatar
and yeah the SES light does come on when the key is "on" lol.. good lookin out tho
Old Apr 4, 2006 | 03:15 PM
WS Sick's Avatar
If the A/C isn't on then the compressors clutch should never engage the compressor. If the A/C is on the fan will come on.
Old Apr 4, 2006 | 04:14 PM
You don't need a scanner to check for codes on a 1993. You can flash them with the SES light. My website shows how.
