Fans on way too early
Old Apr 4, 2006 | 04:37 PM
  #16
Camaro91RS's Avatar
Re: Fans on way too early
oh alright I wasn't sure if you could do that with a 93.
just checked it, just good old code 12
what could be wrong if the 2 right hand heat settings are engaging my A/C and drivers side fan?
Old Apr 4, 2006 | 04:39 PM
  #17
Gord's Green Z28's Avatar
Originally Posted by Camaro91RS
Thanks for the quick reply, u the man
I took it to auto zone to see if it would scan any codes. of course, their scanner was broken but they said if there hasn't been a SES light going on, it most likely won't show anything anyways.
One thing I did notice was, if I turn the heat off, they operate normally. Even on the 2 middle vent settings they are fine. But when it's on the 2 right side heat settings, the fans turn on immediately. Hmm?
2 middle vent settings, they are fine....you're referring to the vent (face) and heater (floor). Fan should be off until proper fan turn on temp.
If you're referring to the 2 right side heat settings (defog and defrost), then your fan will turn on. They run the A/C and the radiator fans when the temp outside is above 4 degrees C. (40 degrees F). Since it was probably colder than this outside in Michigan back in March, your fans were staying off.
The A/C will click on and off when the outside temperature is too cold. Not enough pressure in the system when it's cold outside. It protects the A/C from too low of pressure (I believe)
EDIT: I see you have a 93 which had a different cooling fan setup (1 and/or the other fan on/off) from the later models (both on or both off)
Old Apr 4, 2006 | 05:45 PM
  #18
Camaro91RS's Avatar
wow that's good news, thank you so much
Old Apr 4, 2006 | 10:07 PM
  #19
EnerjetF67's Avatar
If the compressor is kicking in in the two heat settings you describe the fan will ALWAYS kick on due to the flag in the PCM for "A/C request" being set to true. Is this the defrost position or defrost and floor position ?
The A/C compressor is ONLY off in FLOOR ONLY or VENT ONLY position even if the heat **** is in full HOT.
Old Apr 5, 2006 | 10:40 AM
  #20
silentsprintero's Avatar
just buy a toggle switch and 10' of wire, take the hot wires from both fan motors and run the switch through the firewall and mount in under your dash, easy $5 fix
-Chris
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
