fans not working properly
Old Aug 17, 2003 | 09:13 AM
red 95 z28 lt1's Avatar
latley my fans arent working properly i have them programmed to turn on at 172 and off at 165 from a hypertech power programmer, also have 160*powerstat. one day the temp was getting a little high and i couldent hear the fans running. changed the temp sensor in the waterpump and they worked a little bit. reset the pcm and re programmed it and it they dident work. now i can only get 1 fan to work its the 2nd coolant fan thats at high speed. i kept switching relays and eventually it would work but then stop working. is there any way i can jump out the relays w/o blowing a fuse? or testing the relays?
also there is enough coolant and i have bleed the system.
please help its my only car! thanks
Old Aug 17, 2003 | 10:10 AM
anyone please!
Old Aug 17, 2003 | 05:27 PM
thanks i guess ill have to just buy another car and torch this one!
Old Aug 17, 2003 | 05:30 PM
TMDZ28's Avatar
hey hey no need to get mad, get glad man.
JK
maybe your fans is toast?? i know my cooling system is a little weird, it cant make the coolant cool enough to go to 177*. but from your stroy, it sounds like an electrical problem though.
Old Aug 17, 2003 | 06:49 PM
thanks for the reply. i will look into checking the fans
DirtyDaveW
Dec 1, 2016 05:37 PM
Britbilly
Jan 7, 2015 08:49 PM
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
Eddie Z-28
Sep 4, 2002 11:58 PM
