fans not coming on
Old May 30, 2007 | 06:15 PM
brucetrentcamaro212's Avatar
fans not coming on
My fans are not coming on. I checked the relays all are good. I ran the fans manually so i know the fan motor is working so I think the only thing else is the temp sensor on the block. I was wandering if there should be 2 wires for that conector or 1 I only see 1. Wanted to make sure it wasnt a wire broken off. If anyone can help on this please.
Old May 30, 2007 | 07:35 PM
2000GTP's Avatar
What temp is the car running at? The low speed fan doesn't get commanded on until it reaches 226 degrees.
Old May 30, 2007 | 08:36 PM
The sensor in the head (between #1 and #3 cylinders is for the gauge. It has one wire.
The sensor in the water pump is for the computer and it has 2 wires.
You can read all about the cooling system here.
Old May 30, 2007 | 10:00 PM
it would go all the way to the red and they still dont come on. I have had a new temp sensor put in at the pump. didnt know if the sensor at the block was bad. should I go ahead and replace it too see if that will turn them on again. Also one more thing I had the valves adjusted and now there is a sound coming from the motor. it sounds like a squeeke belt but i know its not the belt but it sounds like the noise. did he adjust them to tight..
Old May 31, 2007 | 01:12 PM
2000GTP's Avatar
The sensor in the head only provides an input to the gauge on your dash cluster. Therefore, it does not play a role in the fans coming on or off. Maybe try resetting the PCM by pulling the PCM BAT fuse and letting it sit for 30 seconds or so before plugging it back in.
Old May 31, 2007 | 05:58 PM
I tried that allready. Im just going to wire them up to turn on manually for now and i will have gm look at it.
Also does anyone have any idea on the sound that i hear now after i adjusted my valves.
Old May 31, 2007 | 07:13 PM
2000GTP's Avatar
If the valves were adjusted improperly, that could lead to valvetrain noise. Shoebox has a very good tutorials that goes over the correct procedure: http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old May 31, 2007 | 09:59 PM
FIREHAWK #7's Avatar
i had the same problem about the fans... actually still do.
One of the realys was busted, so i changed it out and still doesnt work.
I decided to change the sensor on the Water pump, and still doesnt work.
Ive tested the fans as well, and cant figure out what the hell is wrong.
For the mean time, i've spliced into one of the fans and connected it to the foglight relay; so whenever i turn on myy foglights the fan turns on.
Im stumped on what it can be...
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
3rd Gen / L98 Engine Tech
Apr 7, 2015 11:49 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
