Fan switch Question
Old Aug 6, 2004 | 04:47 PM
SantaCruz163's Avatar
Fan switch Question
I just installed my manual fan switch as well as doing the !CAGS thru the PCM wires. Well when I turn the key to ON and flip the fan switch to high, both LEDS turn on, and the high speed fans turn on. When I turn the switch to low, the 1 LED turns on, but the fan does not turn on. Has this happened to anyone using the switch? How do I fix it?
Old Aug 6, 2004 | 04:53 PM
Re: Fan switch Question
Did you visually verify what fans were running?
Was this a home-made switch? Basically you wire it like it is supposed to be wired and it works. Sounds like your ground is not getting to the relay wire when you have it in low speed.
Old Aug 6, 2004 | 05:17 PM
Nope, not homemade. It is the switch that Speed Specialty sells. I got it in the last GP. I'll check the fan visually to see if its on, I was listening for it before.
Edit: I just checked my low speed fan and it was not on with the switch. Could I have a blown fan fuse I mean, my high speed fans work by the switch, but no low speed. I know it's not a big deal, but I'd still like it to work
Old Aug 6, 2004 | 08:00 PM
newWolforder's Avatar
you might want to goto that thread speed speacialty had a few problems with that last switch a few people posted problems with it ..also did you order it for obd1 or obd2 ?
Old Aug 6, 2004 | 10:43 PM
Either the switch is not putting out a ground to the green relay wire or it is and you are not connected well to the green relay wire.
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
Rich_z28
Sep 8, 2002 12:00 AM
sfGi8nt
Aug 1, 2002 05:54 AM
