Fan Relay and a stripped sparkplug
Old Jan 9, 2005 | 04:38 PM
ellootre's Avatar
Hey all. After going through the chore of replacing my busted water pump, I went into the problem of inoperating fans on my 1997 Z28.
For the fans:
I had to replace the grounding wire on the fan and fan 1 works when I by-pass the relays. When the relay is in, and the car hot, the fan still doesn't come on! I checked the voltage across the relay (to activate it) and my multi-meter checks it to be 13V. I checked the relay with a 9V battery and it does click over and has continuity on the two poles.
For the plug:
I pulled my #8 sparkplug to replace it, and found that it had some weird orange stuff and what looked like a copper holder contraption around it. Well paying that no mind, I tried slipping the new plug in. To my astonishment - it wouldn't tighten down! So putting two and two together (and the fact that the plug I removed didn't match the other 7 plugs I removed), I concluded that some jack-a-hole stripped it out previously, and had some sort of way to fix it up. So for the time being, what would be a way to fix it so I could drive my car for a day or two, and what would be the best long-term way to fix the problem?
Thanks for the replies in advance
Old Jan 9, 2005 | 05:40 PM
Re: Fan Relay and a stripped sparkplug
Long term, you will probably have to pull the head and have the threads repaired. Short term, I can't think of any good options.
Old Jan 9, 2005 | 06:04 PM
hsyr's Avatar
Take some JB Weld and cover the threads on a spark plug with a good amount. Then carefully screw it in the head until its tight but the threads are still straight. Unscrew the plug then let it sit for atleast 12 hours. I would think that should hold you until you could pull the thread and have it done right. Good luck
Old Jan 9, 2005 | 11:53 PM
ellootre's Avatar
Thanks for the replies! Anyone know how much it's going to run to get the thread retapped? Or should I just start looking for a new set of heads?
Apr 27, 2015 06:08 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jul 4, 2005 05:00 PM
