Fan On/Off temps -- Modify With Resistor at Waterpump Sensor?
Old Nov 11, 2003 | 07:58 PM
Stoopalini's Avatar
If the PCM is controlling the fan on/off temps by using the resistance of the sensor in the waterpump, could a resistor be wired in series to make the PCM turn the fans on before the temp is 226*F, or would the PCM make too many other adjustments for the cooler running temps to be worth it?
Just a thought ......
Thomas.
Old Nov 11, 2003 | 09:18 PM
Best not to fool the pcm. Too many other calculations are made using the temps. MHO.
Old Nov 11, 2003 | 11:02 PM
Stoopalini's Avatar
Ya, I was kind of expecting that ..... the more I thought about it, the more I convinced myself it's a bad idea
Wouldn't the PCM start to pull timing due to the high reading from the sensor?
Thomas.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
