False knock retard? Take a look at the log please.
Old Jul 20, 2004 | 08:29 PM
zx1216's Avatar
Red face False knock retard? Take a look at the log please.
hey, First of all i have already tried the computer page and it only got 14 views and no replies.i've been pissing around for almost 6 months tring to figure out where all my knock retard is coming from. I just seafoamed my car and installed a 160* stat. I have a log from freescan in excel. Can someone confirm that this looks like false knock? It looks like it pulls it out real fast and then slowly adds it back in. I am also ran about a 50/50 mix of 110 race gas and 93 oct and i still was geting kr. I have no way of hosting it so i would have to email it to you. Thanks,
Nick
Old Jul 20, 2004 | 09:28 PM
LWillmann's Avatar
Re: False knock retard? Take a look at the log please.
When pulling timing, the PCM will pull timing aggressively (fast) and return it slowly because it's avoiding getting what it perceived as knock again.
If you've run that much race fuel and still got the retard, then I'm going to say that it's most likely false. Have you verified that the header and y-pipe are not hitting the chassis under the car anywhere? Weak motor mounts can allow the a header to tap the k-member (at least in the case of Hooker LT's) causing KR. Have you verified that you don't have an exhaust leak? Are all the plugs tight?
Old Jul 20, 2004 | 10:23 PM
zx1216's Avatar
i had a loose plug before and i think thats where the knock was coming from but i tightened it up and i'm still geting it, i have been geting the kr before i installed the headers so i don't think that was it.
fift5
11
Oct 1, 2015 10:31 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
navtool.com
Sep 24, 2015 03:30 PM
