Failed smog, what to fix?
Old Jul 15, 2003 | 05:44 PM
ixd97z28's Avatar
Well I went and got it tested today, FAILED! This really sucks because my registration is up next week. This is why it failed:
The following monitors were not ready: 3
Catalyst
EGR system
Oxygen sensor heater
What the hell does this mean? Am I going to be able to fix it by next week or am I **** out of luck? Before getting my car smogged I pulled my PCM BAT and PCM IGN fuse because I have a SES light that I can't seem to fix, could this cause the problem?
Thanks, Dan
Old Jul 15, 2003 | 05:50 PM
96TurboTA's Avatar
Pulling the fuse may have caused the problem. I'm not sure, but the results of those test may be stored in volatile memory, and when you pulled the fuses, it erased it. You need to take the car out and do at least one complete driving cycle as described by GM. The car will run those tests.
Old Jul 15, 2003 | 05:54 PM
ixd97z28's Avatar
But by doing that my SES light will come on, and I will fail anyways. The SES light comes on for the stupid EVAP Purge Solenoid that I've replaced and came seem to fix.
Dan
Old Jul 15, 2003 | 06:55 PM
96TurboTA's Avatar
Did you make sure to put the lines on correctly? Also if the lines are correct, maybe the carbon canister is bad. You've got to fix the problem. There's no way out of it. Those tests can only be completed by driving the car, so if you want to pass then fix it.
Old Jul 15, 2003 | 06:57 PM
ixd97z28's Avatar
Lines are on fine, one thing I'm thinking about trying next is the switch that's before the EVAP Purge Solenoid. If I don't hear it clicking on and off then it's bad. I also have a new EVAP Canister, think I should replace it as well?
Dan
Old Jul 15, 2003 | 07:15 PM
96TurboTA's Avatar
I had my canister go bad a couple years ago. I replaced the cansister, and blew the charcoal out of the lines. The SES light still came on. So I then replaced the solenoid, and sensor before the solenoid. The SES light came on again. I checked the lines going to the solenoid, and found I had them backwards. Problem was solved.
Old Jul 15, 2003 | 08:07 PM
ixd97z28's Avatar
I will give that a try as well, thx for the replies!
I think resetting the pcm caused the sensors not to operate, so my first goal is to get rid of the codes causing the SES light so I don't have to clear it before smogging.
Dan
FredM
Aug 14, 2015 01:49 PM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
Boss002
Jul 24, 2015 10:47 AM
colts0455
Jul 8, 2015 12:21 AM
