Failed emissions... help!
Old Aug 9, 2004 | 05:59 PM
davepl's Avatar
I just failed the idle part of my emissions (barely passed on the cruise portion, but did).
I had 1229 PPM of HC, and the limit is 220. So it wasn't even close. It's a 396 LT1 w/ 236/236 cam, long tube headers and no cats.
I leaded it out as much as I could for the retest (I have a FAST system with wideband) and the headers cooked my brake booster which now leaks (Arrrgh!). That only brought it to 1000.
Given that it got a little better when I went even leaner, I don't think it’s a lean misfire.
I'm running 28 degrees of timing at idle. I think I can improve some by doing down to 20 deg. I can add a gallon or two of alcohol to the tank, but I don't think that's going to help.
Anything else I can do to get a moderately big cam and no cats to pass at 220 ppm?
Thanks!
- Dave
Old Aug 9, 2004 | 06:04 PM
PsstTA's Avatar
Re: Failed emissions... help!
nope
Old Aug 9, 2004 | 06:18 PM
davepl's Avatar
That was useful. Do you know this authoritatively? I can find posts that claim running 10-20% alcohol it will pass... but if your post contained actual content based on prior experience, I'd love to hear more detail.
Old Aug 9, 2004 | 06:23 PM
ss#1230's Avatar
try some cats.....they may be useful.
Old Aug 9, 2004 | 06:26 PM
davepl's Avatar
Dry some cats? You mean like with a blow dryer? What do I do with them once they're dry?
Any useful posts welcome...
(oh, I see you edited your post, so now I have to too)
Old Aug 9, 2004 | 08:44 PM
Janny's Avatar
I doubt you'll get anywhere without cats, but having had the same problem I can tell you that having the engine temp up to normal or stock levels (I have 180 stat) by turning fans off, helped me a lot. In fact, I think the main cause of my failure to pass on the first try was having the engine too cool. For insurance purposes, I retarded the timing to 12 degrees advance for anything beneath 3000 rpm, I bumped the idle up to 1150 rpm, and i put a full gallon of methyl hydrate in an almost empty tank. This did the trick for me.
Old Aug 9, 2004 | 11:32 PM
ss#1230's Avatar
i wasnt tryin to talk poo.....why dont you get some cats you can bolt in and out?
Old Aug 9, 2004 | 11:37 PM
** 396LT4 Vortech S-Trim 7.00/2.65 - AFR 210s, 236/236 cam, 1.6:1 Rollers
Does it have a blower or not? Does it have a "blower" cam (114 or greater LSA)? Overlap can be an issue, but not with a blower cam. How did you do on CO?
Old Aug 10, 2004 | 12:38 AM
davepl's Avatar
Yes, my cam is on 114 centers.
So you're recommending that I get cats with collectors on each end so I can replace them with an "off road" pipe?
Old Aug 10, 2004 | 12:53 AM
ss#1230's Avatar
yeah, whatever it takes to pass the test. just have some off road pipes to run untill smog time comes. i may do it later when i get some cash. it will lengthen the life of my cats too id imagine...
Old Aug 10, 2004 | 03:55 PM
neil350's Avatar
You needs cats and an emision tune or cash to get you a sticker. But no way in hell is that thing going to pass with no cats.
Old Aug 10, 2004 | 04:05 PM
davepl's Avatar
Well, with timing and alcohol I got it down from 1200 to 570, but that's still a ways from 220. Made an appointment with the local muffler shop to look at putting cats on it this Thursday...
Old Aug 10, 2004 | 04:34 PM
Ryan's LT1's Avatar
I think the Cats are really going to help you out on this one. I don't see how there was anyway, even with alcohol you were going to get a 396 with a cam to pass. Where do you live?
Old Aug 10, 2004 | 09:54 PM
Spinner's Avatar
Hydrocarbons is unburned crpa in the exhaust. Something cats would be more then happy to burn off/deal with. That's why you pass at cruise and not idle, overlap and big duration means lots of excess out the tailpipe at idle
Old Aug 10, 2004 | 10:21 PM
truedualws6's Avatar
If you were in CA I doubt you could pass at all with that cam. You may
have a chance with cats. Good luck.
