Failed emissions... help!
I just failed the idle part of my emissions (barely passed on the cruise portion, but did).
I had 1229 PPM of HC, and the limit is 220. So it wasn't even close. It's a 396 LT1 w/ 236/236 cam, long tube headers and no cats.
I leaded it out as much as I could for the retest (I have a FAST system with wideband) and the headers cooked my brake booster which now leaks (Arrrgh!). That only brought it to 1000.
Given that it got a little better when I went even leaner, I don't think it’s a lean misfire.
I'm running 28 degrees of timing at idle. I think I can improve some by doing down to 20 deg. I can add a gallon or two of alcohol to the tank, but I don't think that's going to help.
Anything else I can do to get a moderately big cam and no cats to pass at 220 ppm?
Thanks!
- Dave
Thanks!
- Dave
Re: Failed emissions... help!
That was useful. Do you know this authoritatively? I can find posts that claim running 10-20% alcohol it will pass... but if your post contained actual content based on prior experience, I'd love to hear more detail.
I doubt you'll get anywhere without cats, but having had the same problem I can tell you that having the engine temp up to normal or stock levels (I have 180 stat) by turning fans off, helped me a lot. In fact, I think the main cause of my failure to pass on the first try was having the engine too cool. For insurance purposes, I retarded the timing to 12 degrees advance for anything beneath 3000 rpm, I bumped the idle up to 1150 rpm, and i put a full gallon of methyl hydrate in an almost empty tank. This did the trick for me.
** 396LT4 Vortech S-Trim 7.00/2.65 - AFR 210s, 236/236 cam, 1.6:1 Rollers
yeah, whatever it takes to pass the test. just have some off road pipes to run untill smog time comes. i may do it later when i get some cash. it will lengthen the life of my cats too id imagine...
You needs cats and an emision tune or cash to get you a sticker. But no way in hell is that thing going to pass with no cats.
Well, with timing and alcohol I got it down from 1200 to 570, but that's still a ways from 220. Made an appointment with the local muffler shop to look at putting cats on it this Thursday...
I think the Cats are really going to help you out on this one. I don't see how there was anyway, even with alcohol you were going to get a 396 with a cam to pass. Where do you live?
Hydrocarbons is unburned crpa in the exhaust. Something cats would be more then happy to burn off/deal with. That's why you pass at cruise and not idle, overlap and big duration means lots of excess out the tailpipe at idle
