Extremely Rich Condition
Old Mar 22, 2008 | 10:21 AM
z28camaro1090's Avatar
i have been running extremely rich since i bought my car 3 months ago. i changed plugs and they had the rich black coat over them.. im wondering if the guy before me having a larger throttle body with no other mods might be the cause any ideas?
Old Mar 22, 2008 | 10:29 AM
A larger throttle body will not cause it to run rich, whether there are other mods or not. Could be many things, including faulty IAT sensor, faulty MAP sensor (both critical to your speed-density system), faulty coolant temp sensor, faulty O2 sensors or wiring, leaks in the exhaust before the O2 sensors, excessive misfires, excessive fuel pressure, leaky injectors, etc.
Have you scanned it for codes?
Old Mar 22, 2008 | 10:44 AM
Me>you's Avatar
Are the plugs you put in pieces of crap??? What did the old ones look like?
Old Mar 22, 2008 | 10:51 AM
the guy before me had bosch in there which i absolutely hate.. i went back to the original AC delco .. i also did discover a small leak from the exhaust manifold gasket on the driver side.. i thought it was a loose rocker but i had the hood open on a cold morning and saw it shooting out when i was reving from under the hood.. mechanics tell me that leak wouldnt be enough to do that though
Old Mar 22, 2008 | 10:52 AM
and btw they where covered in black stuff and wasnt oil i matched it up online to a plug they claimed was from rich conditions
Old Mar 22, 2008 | 10:56 AM
Me>you's Avatar
Hmm...so it ran better before you changed plugs, and the plugs that came out don't look as the new ones have been described???
Old Mar 22, 2008 | 01:14 PM
no i havent pulled the new ones i put in out sorry for the confusion. i only pulled his out. but i can still smell the same rich condition so i would imagine mine will look the same. and i changed the o2 sensors 2 weeks ago
Old Mar 22, 2008 | 01:37 PM
ROUDA's Avatar
I have some mods done to my car but I have the same problem my o2s were black when I changed them. the o2s didnt help with the rich conditions.
Old Mar 23, 2008 | 10:45 AM
nope when i pulled them they didnt even look that bad.. the plugs where black but thats all.. im thinking about maybe doing a distributor and hotter burning plug and better wires..
Old Mar 23, 2008 | 09:30 PM
An exhaust leak before the O2 sensors causes a rich condition. Did you pretty much write off any of the other potential problems I mentioned? Did you ever scan it?
F'n1996Z28SS
Jun 3, 2015 09:39 AM
May 1, 2015 01:14 PM
96SilverRam
Apr 30, 2015 03:43 PM
CARiD
Apr 8, 2015 08:08 AM
Apr 3, 2015 10:54 AM
