extreme crankcase pressure
Old Aug 23, 2007 | 04:15 PM
  #16
Mikey97Z's Avatar
Originally Posted by speed_demon24
With the stock PCV setup the crankcase is NEVER under vacuum.
Actually, the crankcase is USUALLY under vacuum, since its air is being sucked into the intake.
But with a supercharger, the intake is sometimes pressurized.
Old Aug 23, 2007 | 04:32 PM
  #17
speed_demon24's Avatar
Hook up a vacuum gauge to the crankcase and show the gauge with the car running. No one has done this yet to prove me wrong... If its under vacuum its such an insignificant amount that it won't even register on a gauge.
Old Aug 23, 2007 | 05:27 PM
  #18
Originally Posted by RIGRUNNER
I am not a genius but if a cranksace was under a vacuum you could hook your brake booster to the valve cover and be good. What is vacuum anyways? I think it is a lack of atomosperic pressure. It wont hurt it to have a lil vacuum but not to much or you make suck all the oil out of the motor. They do run vacuum pumps on cars the have a bit to much blow by. I.E. blower cars,turbo, high compression that are worn out!!!.
There is nothing wrong with vacuum in the crankcase. Ultra high performance engines often run a vacuum pump to maximize cranckcase vacuum. Helps stabilize the rings. Design of the system will minimize oil entrainment.
Have you hooked up that vacuum gauge to prove us wrong? And now were apparently changing the discussion to whether the vacuum is "significant".
Old Aug 23, 2007 | 05:44 PM
  #19
I would if my car was running.... And to me if the vacuum doesn't show up on a vacuum gauge there is no vacuum to talk about. The air circulates through the crankcase its that simple, there is no vacuum to speak of. And if your intake/maf is a restriction at idle/part throttle driving you have one of the most restrictive intakes out there.
Old Dec 26, 2007 | 03:56 PM
  #20
Wims97T/A's Avatar
Well after some busy months at work and searching for interest again i finally pulled the engine out of the bottom.
this is how cyl. and piston 1 looks now .
Old Dec 26, 2007 | 04:12 PM
  #21
Wild1's Avatar
Time to bore it .030 and go for a 355 or a 383.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
May 1, 2015 01:14 PM
96SilverRam
Apr 30, 2015 03:43 PM
Apr 3, 2015 10:54 AM
