externally balanced motor,T56,flywheel question
Old Jan 8, 2009 | 12:35 PM
D-BoZ28's Avatar
I'm about to purchase a stroker that is externally balanced but was hooked up to an A4. Now my concern is will it bolt up directly to my flywheel and T56 without any problems or will I have to get a new flywheel? Or have the flywheel balanced?
Thanks in advance
Dave
Old Jan 8, 2009 | 01:00 PM
Stl94LT1's Avatar
You will need to get your flywheel match-balanced to the A4's flywheel.
Old Jan 8, 2009 | 09:41 PM
87bandit's Avatar
you can't go externally balanced on an lt1 from what I remember
damper won't clear the opti
Old Jan 9, 2009 | 01:40 AM
ACE1252's Avatar
LT1's from the factory are externally balanced. Weight cast in on the back side of the flywheel(along with press in weights in holes around the outside of the flywheel) and damper.
Old Jan 9, 2009 | 01:42 AM
ACE1252's Avatar
Thanks in advance
Dave
Any way to speak with the shop that did the motor? You could quiz them on how they balanced it.
Old Jan 9, 2009 | 11:09 AM
87bandit's Avatar
Originally Posted by ACE1252
LT1's from the factory are externally balanced. Weights in the flywheel and damper.
lt1's are an internal/external
I'm talking about an aftermarket RA, when you order one you have to go internally balanced, aftermarket gen 1 balancers will not clear an opti spark.
Old Jan 9, 2009 | 03:00 PM
Not true. There is no "balancer" on the front of an LT1 engine. Its only a harmonic damper. So you don't need to change it. The external balance is done with a weight on the flywheel (M6) or on the flexplate (A4). If you couldn't build an aftermarket LT1 stroker with an external balance, my engine wouldn't be running right now
Old Jan 9, 2009 | 03:10 PM
D-BoZ28's Avatar
so would i be ok with balance matching the my flywheel with the flexplate? Or should i get an aftermarket flywheel? thanks for the help guys
Old Jan 9, 2009 | 09:32 PM
87bandit's Avatar
I understand it is a dampener on the LT1, I was stating that with most external kits you see they come with a balancer and flywheel. I was talking in general about the kits that you mostly see that are external balance won't work on an LT1 because they rely on balancing the RA with the balancer and flywheel included, but the balancer won't fit on an LT1. I assume what you have isn't a kit but a pieced together rotating assembly
Old Jan 10, 2009 | 11:08 AM
You need an LT1 specific kit.
Old Jan 10, 2009 | 05:37 PM
87bandit's Avatar
yeah, just that I see alot of people make this mistake on forums and pick up 2pc rear main or gen 1 external balance kits so I usually enter a discussion expecting one or the other
HectorM52
Jul 30, 2017 11:46 AM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
1LEThumper
Jul 14, 2003 12:45 PM
