Extended wheel studs?
Old Dec 18, 2003 | 01:38 PM
12SCNDZ's Avatar
OK...The end of last season I went 12.0. Kinda bittersweet, as that trip turned my 10 bolt into a pile of clunking junk.
I've got everything ready to go back together...welded housing tubes, Auburn posi, 3.73 Motive gears, solid "crush sleeve", all new bearings and seals, etc.
The 10 boilt is probably only going to see another year before a 9" swap, so I'm not really planning on buying aftermarket axles yet.
My question has to do with putting extended studs in my stock axles. Has anyone tried to drill and tap their axles for screw in studs? I like the idea of screw in studs because they're easier to replace if one breaks.
What's everyone else using? YES, I know aftermarket axles already come drilled and tapped.
Frank
HarleyZ28
Oct 5, 2015 06:23 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
Catmaigne
Dec 25, 2014 12:16 PM
Ken95Z28
Sep 15, 2002 12:37 AM
squinn
Aug 4, 2002 01:06 PM
