experimental lt1
Old Jun 6, 2006 | 02:16 PM
redbird92's Avatar
experimental lt1
does anyone know of any experimental lt1? if so do you know what they make as in #'s?
thanks matt
Old Jun 6, 2006 | 02:27 PM
way1and3r's Avatar
Re: experimental lt1
Experimental in what way? I would imagine not, as the LT1 has been out of production for a few years now.
Old Jun 6, 2006 | 02:33 PM
thanks matt
Not really sure what you mean, but this board is full of people "experimenting" with their engines.
Old Jun 6, 2006 | 02:43 PM
Sweetred95ta's Avatar
Wasn't there an LT2 or LT5 or something with a DOHC setup? I've seen picures before. Is that the kind of experimenting you're talking about?
Old Jun 6, 2006 | 02:50 PM
1quickTA's Avatar
Yeah there was an LT5 (and LT4 for that matter as I am sure you know). The LT5 was a bad-*** motor but was a whole different engine with the overhead cams and such. I really don't know what you are asking though
Old Jun 6, 2006 | 02:55 PM
MEAN LT1's Avatar
That would be an LT5. But if your really good you would knowabout Project Orange.
Old Jun 6, 2006 | 03:05 PM
DrewHMS97SS's Avatar
The LT5 was designed in europe for GM. I dont remember which vette they put them in, but its a pretty mean motor.
As for the LT4, its basically and lt1 block with 4 bolt mains, redesigned heads/cam, and a new intake to match new heads changed intake port angles. They also came stock with 1.6 rockers.
Old Jun 6, 2006 | 03:12 PM
Sparkz28ss's Avatar
the LT5 was in the ZR1 .....it was designed by lotus(headed by Graham Behan now working at LPE) and gm ......but assembled by MerCruiser( project manager was Gary Cline ...who is now working for GM Powertrain)
Old Jun 6, 2006 | 03:13 PM
Honda Hunter's Avatar
LT5
A GM LT5 engineImmediately prior to the release of the second generation Small-Block, General Motors released a largely unrelated engine which also used the LT name. The LT5 was a special engine indeed. It was an all-aluminum 349 in³ (5.7 L) small-block V8, but was entirely different from any of the other Chevrolet 350 engines. The bore and stroke were both different at 3.9 by 3.66 in (99 by 93 mm) instead of the usual 4 by 3.48 in (102 by 88 mm) and it featured a Lotus-designed 32-valve DOHC head. It was hand built by specialty engine builder, Mercury Marine. This engine produced 375 hp (280 kW) and 370 ft·lbf (502 Nm) for the 1990-1992 Corvette ZR-1 and jumped to 405 hp (302 kW) and 385 ft·lbf (522 Nm) for 1993 to its final year in 1995, thanks to cam timing changes and improvements to the engine porting. 1993 also added 4-bolt main bearings and an exhaust gas recirculation system. The engine was not used in any other vehicle.
LT4
The LT4 was a special high-performance version of the new-generation LT1. It was introduced in the 1996 model year, for the last year of the C4 Corvette, and came standard on all manual transmission (6-speed equipped) C4 Corvettes.
The engine was passed down to special versions of the Camaro and Firebird the next model year. With the addition of new higher-lift cam and port-matched intake runners, it produced 330 hp (246 kW) and 340 ft.lbf. (461 Nm) of torque. The LT4 was almost identical (in terms of power) to the all-aluminum LS1 of the C5 Corvette.
The LT4 was available on the following vehicles:
1996 Chevrolet Corvette when equipped with 6-speed manual transmission (includes all Grand Sports)
1997 Chevrolet Camaro SLP/LT4 SS 6-speed
1997 Pontiac Firebird SLP/LT4 Firehawk 6-speed
http://en.wikipedia.org/wiki/GM_LT_engine
Old Jun 6, 2006 | 03:17 PM
109 total camaros in 97 had the lt4 engine, and 29 firehawks.
Old Jun 6, 2006 | 03:31 PM
Colin91Z's Avatar
The LT5 was produced in Stillwater, OK
Useless info I know, but I thought it was kinda cool
Old Jun 6, 2006 | 03:40 PM
93redBirdMan's Avatar
my buddy used to have a 1990 zr1. Lemme tell ya, that thing moved nicely
Old Jun 6, 2006 | 03:49 PM
user 647483's Avatar
Oh boy did they ever
Felt like a Northstar
http://www.rogerscorvette.com/spots/...r1_engine2.jpg
They make nice coffee tables too.
Old Jun 6, 2006 | 04:01 PM
blkchevyz's Avatar
i remember reading about a 305 or 302 lt1. not really experimental, gm just de stroked it.
wasnt that impressive for power, was more of a gimic thing.
car did look good though... lt1 with a one off cowl hood.
Old Jun 6, 2006 | 04:15 PM
bpipe95's Avatar
Gm built a test mule camaro that had an lsX series motor that had 302 ci it was in a few mags .
