Exhaust popping due to bad O2 sensors?
Old Jun 28, 2004 | 06:20 PM
PatriotTA's Avatar
I have a custom true dual exhaust system with an x-pipe. There is more info in my sig. I have some popping in my exhaust that is really annoying me. It does not happen at wide open throttle or cruising at a decent RPM. It only happens at idle or very low RPMs or deceleration. Could bad O2 sensors be causing this? I have pretty much ruled out an exhaust leak, so does anyone have any other ideas?
Old Jun 28, 2004 | 06:47 PM
DonHood's Avatar
Re: Exhaust popping due to bad O2 sensors?
Popping exhaust is usually a sign of running rich, and that can be caused by O2 sensors. That may not be the problem in your case though, but it's certainly a possibility.
Old Jun 28, 2004 | 07:49 PM
PatriotTA's Avatar
Other than the O2s being bad, what could cause the car to run rich?
Old Jun 28, 2004 | 08:03 PM
1racerdude's Avatar
poping
An exhaust leak will cause it to pop also.
Old Jun 28, 2004 | 08:29 PM
toegead93's Avatar
check for any leaks, that's my car's problem.
Old Jun 28, 2004 | 09:04 PM
PatriotTA's Avatar
I'm pretty sure there are no leaks. I have water coming out of the exhaust tips when I really get on it, but there are no drips anywhere on the pipes. I'm beginning to think its just the duals.
Old Jun 28, 2004 | 09:29 PM
charles94ta's Avatar
If you read the owner's manual, you will see that a slight popping noise in the exhaust is considered normal...
But it could be from runnig a little too rich on deceleration or idle...
Old Jun 28, 2004 | 10:21 PM
magius231's Avatar
the popping comes I believe from the decelleration fuel cutoff built into the computer, basically cuts off fuel flow to the engine when you start slowing down. Its perfectly normal and I haven't seen an LT1 yet that doesn't do it. Its MUCH more pronounced when you have a free flowing exhaust.
Old Jun 29, 2004 | 03:07 PM
IslandZ's Avatar
A vaccuum leak can also cause the popping, check all your vaccuum hoses for dry rot.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Amshnock
14
Jan 18, 2015 11:47 AM
Jazsun
Dec 29, 2014 12:14 PM
