Exhaust popping due to bad O2 sensors?
I have a custom true dual exhaust system with an x-pipe. There is more info in my sig. I have some popping in my exhaust that is really annoying me. It does not happen at wide open throttle or cruising at a decent RPM. It only happens at idle or very low RPMs or deceleration. Could bad O2 sensors be causing this? I have pretty much ruled out an exhaust leak, so does anyone have any other ideas?
Re: Exhaust popping due to bad O2 sensors?
I'm pretty sure there are no leaks. I have water coming out of the exhaust tips when I really get on it, but there are no drips anywhere on the pipes. I'm beginning to think its just the duals.
the popping comes I believe from the decelleration fuel cutoff built into the computer, basically cuts off fuel flow to the engine when you start slowing down. Its perfectly normal and I haven't seen an LT1 yet that doesn't do it. Its MUCH more pronounced when you have a free flowing exhaust.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
