Exact balancer needed
Old Jul 18, 2005 | 11:41 AM
Wildwill2855's Avatar
Ive read alot on here about the balancers but im pretty lost, i just got a forged 383 stroker externally balanced. I need an balancer,exact part to use and will i need a new flex plate i think, but im not for sure. i always hear buy the 350.00 ati fluidamper but im not twisting 15k rpms either. Thank you for your help, the shop just asked me what i am going to use thank you. asap
Old Jul 18, 2005 | 11:58 AM
Re: Exact balancer needed
The front will require a neutral balanced damper. ATI and Fluidampr make them, but you could also find others on the internet, or in Summit of JEG's. It has to be F-Body LT1-specific (Corvette will not work), and it has to be selected based on the year of your car (which you don't mention). The OBD-II cars need a different hub length because of the crank position sensor.
NHRA requires an SFI-rated damper when you go under 11.00-seconds.
Old Jul 18, 2005 | 12:00 PM
the block is a 94, but my car is a 97. i called a machine shop and they just said if its externally balanced you need exteranlly balanced parts as well.
Old Jul 18, 2005 | 12:02 PM
Dave89IROC's Avatar
LT1's are nuetral in front and external in the rear
Old Jul 18, 2005 | 12:25 PM
so i could use the stock balancer and i would need a new flex plate correct?
Old Jul 18, 2005 | 12:53 PM
i called the engine shop and told him, he said all ive got now will carry over from my 97lt1 to the 94 block. i asked if he was sure he said yes, the front is nuetraly balanced and the back is externally balanced. so he said the flexplate and hub would work.
Old Jul 18, 2005 | 02:36 PM
was he correct by telling me this?
Old Jul 18, 2005 | 02:53 PM
Dave89IROC's Avatar
if you do not have the CPS reluctor in there, the 97 hub will be to short for proper belt alignment, you need a 93-95 front hub, everything else will work
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
