ex 224/230
Old Feb 16, 2005 | 07:37 PM
black95z0122's Avatar
ex 224/230
anybody have a sound clipof the ex 224/230 w/ 114lsa? i been doing tons of searches and haven't found one. I've been searching for a cam i was going to go w/ the lt4 hot cam but i heard that ppl get better numbers some of the ex series but i also want a cam w/ a nice lope and cam pass mass emissions
Old Feb 16, 2005 | 07:51 PM
InGodITrust's Avatar
Re: ex 224/230
I don't have a sound clip for you, but I can tell you that my cam has a nice lopey sound to it. It's not really aggressive, but enough for others to hear! It sounds really good!! I think you'll like it!
Old Feb 16, 2005 | 08:02 PM
Re: ex 224/230
ur sig says u have the ex 224/230 w/ 112lsa i was looking for info for the same cam but w/ 114lsa i guess the 112lsa can't pass emissions or at least its not likely. i've heard the ex 224/230 w/ 112lsa and i think it sounds great.
Old Feb 16, 2005 | 08:13 PM
Re: ex 224/230
I don't have any sound clips of mine (114LSA), but it is not too lopey. Just enough to let you know it is there. You can get more lope by reducing the idle speed, if that is what you want to do.
Old Feb 16, 2005 | 08:21 PM
Flyin_Z28's Avatar
Re: ex 224/230
I have a custom 224/230 on a 114LSA. Don't have any sound clips. Really like it despite the little amount of time I've had it. With the cutout open you can really hear the lope (stock idle level). With the cutout closed you can barely hear the lope (kinda sleeper). BTW, you can get cams with 112LSA's to pass emissions.
Old Feb 16, 2005 | 08:25 PM
Z95m6's Avatar
Re: ex 224/230
The 224/230 on a 112 should pass emissions pretty easy. They were designed to have less over lap than similar cams. The 224/230 on a 112 has less overlap than a hot cam and hot cams pass all the time.
Old Feb 16, 2005 | 10:28 PM
Re: ex 224/230
is this true that it'll pass w/ 112 lsa? i've been reading alot of the posts about it before and alot of ppl seem to think 112 is too much to pass. i know "Zmydust" has passed in flordia but i don't know how common that is. i would really prefer the 112lsa version but i need to pass emissions. i know in mass its the test where they test ur exaust gasses at idle and at 30 mph on a dyno or "tredmill" every two years.i have to get inspected this month and its a year where they test the exaust. so i'll do that befoer the cam and have two years to get my tunning right.
By the way alot of ppl talk about getting a "good tune" how do i do this? i know guys like madz28 do mail order tunes but what else is there and how do i really get a good tune?
Old Feb 16, 2005 | 10:31 PM
DarkHorse's Avatar
Re: ex 224/230
I wouldn't consider my GTP4 'aggressive' by any means but you do notice that it's there.
226/236 114lsa
Buddies GM847 is much more intimidating
Old Feb 16, 2005 | 10:36 PM
Re: ex 224/230
226/236 114lsa
gtp4? who makes that?( sorry if that a stupid question) and do u pass emissions?
Old Feb 17, 2005 | 08:18 AM
DarkHorse's Avatar
Re: ex 224/230
GTP makes the cam
www.gtp-racing.com
I think that's the link
Old Feb 17, 2005 | 09:11 AM
Re: ex 224/230
yay! a bunch of new cam to investigate and think about.
Did u pass emissions w/ the gtp4?
Old Feb 17, 2005 | 12:09 PM
Z95m6's Avatar
Re: ex 224/230
I could very well be wrong on this but i bet his cam has a ton more overlap than the 224/230 on a 112 LSA. One because of its duration and two because i bet GTP doesn't have the aggressive cam lobes that the XE cams do.
Old Feb 17, 2005 | 02:37 PM
Re: ex 224/230
hp numbers 224/330 114lsa vs 224/330 112lsa?
powerband differences?
sound clips???
(i know this is a tired subject thanks for the advise)
Old Feb 17, 2005 | 03:06 PM
DarkHorse's Avatar
Re: ex 224/230
No problem with emissions with my setup. My whole plan was to build a mid 12 second car that was totally roller legal. So far so good - this year with the N20 I should dip into the 11's and remain echeck legal.
Old Feb 17, 2005 | 03:58 PM
Re: ex 224/230
that sounds sick. thats really basically my plan, to try to get a 12 second car by the end of the summer i'm going w/ a cam (which one i don't know yet) and 4:10s.
i have a ton of bolt-ons, suspension, headers and exaust,95 M6 Z-28
72xxx on the motor lets see if i spin one after cam install
