EWP working/not working?? (long)
Old Apr 19, 2007 | 10:21 AM
MTBeni's Avatar
I've had a CSR installed for about 2 weeks and put about 250miles on it (the pump itself was used from the board a few k miles). I had no problems until last night. I noticed the temp racing for the red, shut it down. After running the pump, the temp dropped to about 180 (I could hear the pump running). I fired it up and made my way back home. The temp stayed at 180 or so the whole way home. So in my infinite wisdom I decided to turn around and keep going to my appointment. Well, at the exact same place I was last time it did it again. The temp rapidly rising to the red. Did the same thing, drove it home...was fine. That particular road I was on is about 1 mile from the house, and has a very slight incline. Nothing unusual. I chalked it up to a bad Tstat maybe since I reused a pretty old one.
This morning I dropped in a 180 thats about a year old and fired it up....but this time I don't hear the EWP! I let it run a little before noticing, then shut it down. I swapped relays and fuses and still not working. So I pulled the pump to send off for a rebuild and decided to run it laying on top of the engine. It fires right up! WTF. I let it run like this for a few minutes, and seemed fine. Just to be safe, I sent it off for a rebuild anyways. But any suggestions on what it could be? There were no signs of binding.
Old Apr 20, 2007 | 02:46 AM
blown383's Avatar
Did you properly burp the cooling system when you installed the water pump?
-B
Old Apr 20, 2007 | 09:08 AM
asudecat's Avatar
i have the same problem.
It was my ewp that kept cutting off.
Old Apr 23, 2007 | 05:44 AM
MTBeni's Avatar
I thought I had done the cooling sys right. I used the bleed screws, etc. Asudecat, what did you end up doing about the EWP?
Old Apr 23, 2007 | 11:04 AM
asudecat's Avatar
i've got a new one on the way.
Old Apr 23, 2007 | 03:33 PM
MTBeni's Avatar
hehe me too. Actually i had it rebuilt at CSI for $64 including shipping. They got it this morning, and have it back this way by the end of the day. They said they replaced the motor and seal.
parkers Z28
Mar 11, 2016 08:14 PM
Jlo
Feb 3, 2015 09:41 PM
Britbilly
Jan 7, 2015 08:49 PM
Snoman73
Nov 17, 2014 07:22 PM
