EWP wiring help!
Old Aug 16, 2007 | 10:20 PM
Romero155's Avatar
EWP wiring help!
Im wiring up my Meziere EWP with the painless relay kit. Do you guys know where to connect the smaller blue wire to? it says " Attach the 18 gauge blue wire to a switched 12 volt source or water pump switch" I dont know what that means and im not very good with schematics.
Old Aug 16, 2007 | 10:43 PM
palehorse77's Avatar
If you're referring to the blue wire coming out of the relay I wired mine into the 10 amp fuse in the fuse box (ignition).
Mine has worked like a charm for nearly a year now.
Hope that helps
Kirk
Old Aug 16, 2007 | 10:47 PM
SS RRR's Avatar
http://www.projecttransam.com/projects9.asp
Old Aug 17, 2007 | 04:52 AM
Romero155's Avatar
Hope that helps
Kirk
How did you wire it to the 10 amp fuse? did you just splice it into the conection?
Old Aug 17, 2007 | 06:31 AM
SS RRR's Avatar
Did you look at the link?
Old Aug 17, 2007 | 06:39 AM
BigWilly1's Avatar
bump for you... I hope that someone will give you the right answer
Old Aug 17, 2007 | 10:37 AM
lt1chevelle's Avatar
when they say switch 12 volt that mean when you turn the ignition switch on it turns the pump on. so you would want to hook the blue up to the fuse box were is says ignition hot so when the ignitions turns on the wp will 2
Old Aug 17, 2007 | 02:30 PM
SS RRR's Avatar
holy hell...
The link with the install guide is very self explanitory.
Old Aug 17, 2007 | 10:09 PM
Romero155's Avatar
Hey thanks SS, i finally understood the what they were saying. I guess beer and schematics dont get along to well haha. thanks again
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Jlo
Feb 3, 2015 09:41 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
