EWP wiring help!
EWP wiring help!
Im wiring up my Meziere EWP with the painless relay kit. Do you guys know where to connect the smaller blue wire to? it says " Attach the 18 gauge blue wire to a switched 12 volt source or water pump switch" I dont know what that means and im not very good with schematics.
How did you wire it to the 10 amp fuse? did you just splice it into the conection?
when they say switch 12 volt that mean when you turn the ignition switch on it turns the pump on. so you would want to hook the blue up to the fuse box were is says ignition hot so when the ignitions turns on the wp will 2
surreybrad
Apr 22, 2015 06:40 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
