eveything bought except timing chain
ok i had my heads done by lloyd elliott, bought new xe cam,comp r lifters,lloyd did the double springs and ferrara valves new head bolts,30lb svo injectors,all gaskets,one stage cooler spark plugs, are you telling me their is no stronger timing chain unless i get an electric waterpump?i bought a brand new stock chain will i be ok?
There is the LT4 roller chain, that it stronger than the stock LT1 chain.
The other option is a Cloyles double roller that will work if you dont' have a crank-shaft sensor (94's don't though so you'r golden).
Do a seach here for details as many guys have done this.
If you want to go to a LOUD gear-drive design, or an EXPENSIVE belt-drive... or even a cool, O-ringed 2-piece timing cover (which is kind of pointless for an LT1)... you'll need an electric water pump.
