keep blowing fuse?
Old Dec 11, 2003 | 10:54 PM
whitedakota's Avatar
Question keep blowing fuse?
i was going to use my cruise the other day on my way home from work and it just didnt work...any other time it works fine and dandy. i checked the fuse and it was a 10 amp and it was blown its the ac/cruise in the little fuse&relay box in the engine compartment...so i but a 20 amp in there and tried the crusie and nothing...blew again...but a 30 amp in there and the same thing...
any idea on what is causing my problem for the cruise not to work and to blow fuses?
thanks,
steve.
Old Dec 11, 2003 | 11:03 PM
The wrong thing to do is to keep putting larger fuses in it. You are going to make it worse by burning up the wiring. You need a meter or test light and probably some wiring diagrams to trace down the source of the problem.
Old Dec 11, 2003 | 11:06 PM
i agree with you 100% but i thought they might have been some weak fuses or something b/c they were out in an old tool box in my shed...
could you give me and idea on where to start?!?
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
