everybody dynoing 400rwhp and more inside
I hit 392 rwhp thru a 355 with ARE stage 1 heads and a custom nirtous grind cam with out spraying it, and having a rocker stud that broke less then 50 miles later. Went back and dynoed 303 at the wheels with a blown head gasket. Now its fixed, so back I go again to strap the beech down
Q
Q
Originally posted by kmook
This was a setup i had (now a long while ago) but stock ported heads and a xe 230/236 on the stock bottom end.
Dyno Chart
Dyno Chart
Originally posted by simple
was that a chassis dyno or engine dyno? those are pretty impressive numbers! what other mods were involved?
Originally posted by Grease
Advanced Induction "Econoport" heads and a GM847 camshaft (234/242, .539/.558) 412rwhp, 371rwtq. details and dyno info in my sig.
Waz.
Waz.
doesnt ur cam redline @ 6500?
i was lookin at your dyno graph, and it shows you going to 6950 (although you stopped making power before going that high).
Waz.
Waz.
I chose to go with the full race port job AI offers, havent decided on a cam yet. when i was 1st looking at getting heads ported and searching thru all the places that offer them, your numbers were a partial deciding factor on why i chose AI
Guest
Posts: n/a
467 rwhp 420 rwtq, sae correction on a dynojet.
mechanical roller 355 ci, sorry no stock internals. lightweight pistons, pins, rods, assembly. good heads and an intake that flows just as well. lots of little tricks here and there but she'll put down high ten second runs all day long through the t56. need to get weight out of the car but we're like everyone else. always looking for better times.
JB
JB
My car dynoed 360rwhp on a mustang dyno... Take that # times 12%and you get 403 on a dynojet dyno but it still needs tuned more their and that was at 6400rpm most guys with this cam pull to 6800-6900 rpm ... stock bottom end rest is in my sig...
