evap solenoid
Old Jan 9, 2016 | 10:47 PM
94Z28LS1toLT1's Avatar
evap solenoid
Quick question guys,as I've been exploring the engine n looking around,I noticed on the driver side I seen and followed the ground strap,there's an evap solenoid mounted on the bottom,Idk if that's supposed to be there
Old Jan 10, 2016 | 09:18 AM
Re: evap solenoid
There is no EVAP solenoid mounted below the engine that I know of. You sure that is what is is? I also don't know what the heck car you are working on, 'cause you don't provide any info.
I think my new years resolution should be to ignore any post without car info. I feel that anyone serious about wanting help would post that info.
Old Jan 10, 2016 | 11:11 AM
Re: evap solenoid
Rob sorry on mobile phone it's a 94 lt1 camaro.and I'm 100% sure that's what it is
Old Jan 10, 2016 | 11:57 AM
Re: evap solenoid
Post a pic, 'cause the EVAP solenoid is supposed to be on the RH side of the intake manifold.
Old Jan 10, 2016 | 08:34 PM
Re: evap solenoid
Mounted "on the bottom" of what?
How did you determine if it was an EVAP solenoid?
What hoses are connected to it and where do they originate?
Possibly the EGR solenoid (which is on the driver side, but on top of the engine)?
The usual questions ( which a signature would help avoid - this is obviously starting to annoy people) are there any modifications to the engine? Which trans?
Old Jan 10, 2016 | 09:29 PM
GaryDoug's Avatar
Prominent Member
Re: evap solenoid
He has a sig, but apparently it doesn't work with the phone. That seems like a system issue. Why would the B/B system not post a sig regardless of how you logged in?
AIR pump bleed valve? ( I know wrong year but...)
Old Jan 11, 2016 | 12:37 PM
Re: evap solenoid
I know that some phones don't result in appending the signature. In that case, as recommended in my sticky thread:
NOTE: Some phone apps do not append the signature to the bottom of each post. If you are using a phone, and the signature does not appear at the bottom of every post, you are going to have to type the required info in every new topic.
As far as why the BBS software doesn't append from some phone apps is something I can take up with Internet Brands. May take a while, since the Admin of this site seldom comes here, and I often have to go back to the original owners of the site to get action. I've asked for Admin privileges, and have some Admin rights, but apparently they don't want to make me the Admin. Frustrating.
Let me ask the OP what phone system and what app he is using.
[EDIT] PM sent.
Old Jan 11, 2016 | 12:42 PM
Re: evap solenoid
Exactly I'll that's where it's located,I'll take the picture tonight after work. All it is just mounted n has wire connection to it,but no hoses connected to it.
Old Jan 11, 2016 | 12:54 PM
Re: evap solenoid
How did it move from drivers side "on the bottom of the engine" to "that's where it's located" when Shoebox said it should be on the passenger side of the intake manifold?
Shoebox already has a picture of what it is supposed to look like:
http://shbox.com/1/evap_sol.jpg
Old Jan 12, 2016 | 09:46 AM
Re: evap solenoid
Fred i do have the evap solenoid on the intake manifold I'm just saying and wondering why do I have another one too.I'm going to post a picture
Old Jan 12, 2016 | 09:58 AM
Re: evap solenoid
https://photos.google.com/share/AF1Q...JaVlJPZ3ZKR2l3
Old Jan 12, 2016 | 09:59 AM
Re: evap solenoid
https://goo.gl/photos/mXJNkTQ2nUXyGaGe9
Idk if that link worked let me knowI forgot how to post pics on this site
Old Jan 12, 2016 | 10:09 AM
Re: evap solenoid
You didn't copy the full link. I added it.
Are you sure you don't have a 96/97 engine transplant? That does look like the bleed valve shown in Shoebox's AIR pump recall - what Gary mentioned above. Although I don't see the AIR components that would be nearby. The recall was not applicable to the 1994. Only 95 and up, and only the 96/97's have the bleed valve.
Maybe I'm just disoriented from not knowing the angle that the picture was taken from.
http://shbox.com/1/air_pump_recall.jpg
Old Jan 12, 2016 | 10:34 AM
Re: evap solenoid
Oh u got the pic Fred? Yes it's in that pic the 3rd box on top that u showed me,but it was hard to take the picture,yea it looks like the evap solenoid,I was just wondering bcuz no hoses were attached to it
Old Jan 12, 2016 | 10:39 AM
Re: evap solenoid
Good thank you buddy alot of the answer cool
Apr 4, 2016 06:42 PM
KYWes
Dec 18, 2015 09:34 PM
ad356
Dec 6, 2015 08:32 AM
dkred94z
Parts Wanted
Nov 5, 2015 07:21 PM
