EVAP canister?
Old Jul 2, 2003 | 08:45 PM
MLTA96's Avatar
EVAP canister?
on my evap canister there's three outlets for tank, air, and purge. I take it the tank one goes directly to the tank. what about the others and the control valve that's back there also? i have the feeling whoever had the car before me screwed up on putting those on.
Old Jul 2, 2003 | 09:49 PM
MLTA96's Avatar
anyone?
Old Jul 3, 2003 | 12:45 AM
fbird95's Avatar
Yeah that sounds about right. I forget the order they go in off hand, it has been about 3 months since i fixed the connections, becuase i got tired of smelling gas. One collects fumes from the tank, one is for out side air, and the last one runs to the purge silonoid under the hood. If the canister holds proper pressure the fumes will enventually get reburned in the enigne.
Old Jul 3, 2003 | 02:41 AM
MLTA96's Avatar
what does that little check valve thingie go on? the outside air hose or the the purge hose? because it was on the hose from the tank.
Old Jul 3, 2003 | 10:53 AM
jeremyferguson's Avatar
The valve next to the canister goes to the tank. When the pressure in the tank reaches a certain point, the valve opens letting fumes go to the canister.
Old Jul 4, 2003 | 12:03 AM
fbird95's Avatar
I belive the check valve back by the evap canister goes from the canister to the tank.
Old Jul 4, 2003 | 01:03 AM
MLTA96's Avatar
I hooked up the hoses the right way with tank, air in the middle and purge on the other end and my car runs worse. the person who had the car before me had the purge hose going to the tank outlet on the canister. I smell the crap behind my car and around the gas cap. other than trying to find the cause of P0300 code i have this problem now. this car needs to be driven off a cliff.
Old Jul 4, 2003 | 02:44 PM
fbird95's Avatar
Could also be a purge valve problem. I not familiar with that code. If the car runs worse, are sure its hooked up correctly. If its that bad, just disconect it again.
Old Jul 4, 2003 | 04:24 PM
MLTA96's Avatar
i just took it for a drive and i do smell the fumes or vapors coming either from the canister or somewhere. she's hooked up right, it's pretty simple cause the outlets on the canister are labeled for each hose.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
MDZ28
11
Sep 24, 2015 09:15 AM
MDZ28
Sep 7, 2015 09:16 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
