EV6 injectors on a LT1...
Old Nov 26, 2008 | 02:34 PM
ss.slp.ls1's Avatar
Anyone use Cobra (all blue) Injectors or any other EV6 style injector on their LT1? I have a couple questions:
1) Someone mentioned that they might leak, anyone experience that?
2) Also the stock retaining clips won't work on them, any suggestions or would they be fine without the clips?
As they are now, they are very snug in the rails, very difficult to remove them once I put them in, but I don't know if that will change when 40+ psi of fuel runs into the rails. Thanks for your help.
Old Nov 26, 2008 | 04:06 PM
Green96Z's Avatar
I don't know about the leaking, but I couldn't get the clips to fit on my injectors either, and they work just fine, no leaks. A lot of guys run SVO injectors and can't use the clips, and they work fine like that. Just put some silicon grease on the o-rings before installing them.
Old Nov 26, 2008 | 06:34 PM
Do not use any sort of silicon lubricant on a surface that would allow it to somehow enter the combustion process. It contaminates the O2 sensors. A very light coating of motor oil is all you need.
Old Nov 26, 2008 | 06:39 PM
sn8ke eatr's Avatar
^ i just dip my finger in oil and makes sure the whole surface has a nice coat and ive never had any leaks
Old Nov 26, 2008 | 06:41 PM
Green96Z's Avatar
I don't doubt that, but the instructions Racetronix sent me with my injectors told me to use the supplied silicon lube on the o-rings for installation. Of course I didn't smear it on, just a very light coat.
Old Nov 26, 2008 | 07:04 PM
ss.slp.ls1's Avatar
Good to hear.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
