Erratic metallic sound when accelerating
Old Oct 8, 2005 | 10:47 AM
  #31
MyShibbyZ28's Avatar
Re: Erratic metallic sound when accelerating
Originally Posted by MachinistOne
I have the exact same issue that you guys are describing, off-idle at 1100-1400rpms, a metallic rattle.....it is not detonation, spark knock or what-ever, i have narrowed it down to the cat, the filler inside it is breaking down and at low rpms it creates a resonance that vibrates the loose honeycomb in the housing...
Now if any of you have brand new cats on your car you may have detonation, but at that rpm with little or no load the motor should not detonate even with 87 octane.
How many of you with this issue have original cats?
I agree with what EvilBox said. I have original cats at 181,000 miles but I don't think they are loud enough or can make the same noise I'm hearing.
As for the scanner, is it scan data or scantool or what? if it's scantool i can help you but otherwise i don't know anything about the others.
Old Oct 8, 2005 | 11:11 AM
  #32
EviLBoX's Avatar
It's OBD-II software I have installed on my laptop, basically the same as Autotap. I was just wondering what sensors I should look at to help me diagnose this problem as well as my 7* of knock retard.
Old Oct 8, 2005 | 11:21 AM
  #33
Silvershark's Avatar
mine has the same problem, however it is constant with the rpms and sounds like it is only coming from one cylinder. The highest octane gas we can get here is 90. I think it is just a loose rocker arm, though I have comp R lifters, hi tech pushrods and comp rocker arms, so they usually dont come loose after tightening the key and the nut...
So perhaps detonation could be possible for me.
Old Oct 8, 2005 | 01:04 PM
  #34
EviLBoX's Avatar
Hmmm... now that you mention a loose rocker, I do notice a very loud tick coming from my passenger side valve cover. Would that cause knock retard?
Old Oct 8, 2005 | 03:14 PM
  #35
chrisn's Avatar
yup, if its bad enough
Old Oct 8, 2005 | 09:49 PM
  #36
Found out what my rattle is today. It's my exhaust right by my cat. that's barely, hardly, not even really moving, and it's banging against my frame/floors. I mean it's just the slightest movement, i can't move my exhaust with my hand but when you push really hard to the drivers side it'll stop rattling. Maybe this is what's wrong with your guys. Just push on the cat. with your foot from the passenger side to the drivers. But who knows, the sound you're hearing could be totally different from mine.
Old Oct 8, 2005 | 10:09 PM
  #37
chrisn's Avatar
im gonna try that, i recently scrapped my y pipe really bad on a speed bump so that could be it.
Old Oct 8, 2005 | 10:33 PM
  #38
my car hit a curb or something before i bought it. I don't know forsure though because the owner before me didn't know anything about camaros and the underside was all mangled by the fender and such along with the y pipe. So i think that's what did it for me, maybe that speed bump did it for you.
Z28Freak86
Apr 30, 2024 05:37 PM
blkWidow
Apr 21, 2015 01:56 PM
warmeck
Mar 22, 2015 06:43 PM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
