erratic idle....
Old May 9, 2005 | 02:46 PM
Hawk350's Avatar
erratic idle....
what can cause car to idle funny? Sometimes my idle is at 800rpm, and sometimes it is at 1100. The oil pressure is a bit higher that normal also. I understand with more revs, the higher the pressure. What electrical components are located on the intake that would regulate this?
Old May 9, 2005 | 09:21 PM
hellostop's Avatar
Re: erratic idle....
Check egr valve for blown diaphram. use a vacuum pump.
Old May 9, 2005 | 10:39 PM
Jps 1LE's Avatar
Do you have a miss while your driving at all? Is there any knock? If so it could possibly ignition related.
Just as a reference my car had a rough idle (tact jumped abouy the same as yours) i had a miss on one of my cylinders. Check your plugs and wires, could be the problem. Hopefully not an opti issue! Good luck figuring it out
Aug 18, 2015 07:08 AM
80TA
Jun 9, 2005 03:23 PM
vladie22
Feb 26, 2005 09:55 AM
blown94
Jan 30, 2005 12:19 PM
Dan Oldham
Aug 29, 2003 06:23 PM
