engine voltage meter drops under low
Old Dec 10, 2006 | 11:00 PM
Iceman20's Avatar
Hey, I am kinda new to this (well been a member for a while but not really posted much). I have a '97 LT1 TA and have a problem with my electrical system. On idle my car's voltage meter for the battery shows just over 13v but when I put it into gear it drops to below 13 to around 12 and then slowly continues dropping. I've had the alternator tested at Kragen and it was good and I've replaced the battery. I've checked all the cables and am now in the process of replacing the engine ground. Anyone have any thoughts?
Old Dec 10, 2006 | 11:05 PM
ev95355's Avatar
Do you have an underdrive pulley? My car idling in gear will sit just in the red by a sliver, but as soon as i move or put the car in park all is good.
Old Dec 11, 2006 | 05:10 PM
Iceman20's Avatar
Unhappy engine load issue
No, I haven't installed an underdrive pulley system. I don't have the problem at idle but rather when the engine is under load.
Old Dec 11, 2006 | 08:36 PM
2000GTP's Avatar
It might be worth a shot to check the voltage on the battery itself. The voltmeter gauge on the dash has been known to be inaccurate.
Old Dec 14, 2006 | 10:24 PM
Iceman20's Avatar
Wink voltage
The battery is brand new, I'm thinking it might be the engine ground but the LT1 specific braided cable is tough to find.
Old Dec 15, 2006 | 03:56 PM
nicks2ndZ's Avatar
Very true...when i first start my car it reads way past 18v(kind of like the fuel gauge does when you fill your tank up)...you put a multimeter on it and it reads 14.6V...quick and easy way to find out if your really having an overall electrical or gauge problem
Alex Barnes
Jan 24, 2015 10:21 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
pete53
Dec 9, 2014 07:31 AM
