engine voltage meter drops under low
Hey, I am kinda new to this (well been a member for a while but not really posted much). I have a '97 LT1 TA and have a problem with my electrical system. On idle my car's voltage meter for the battery shows just over 13v but when I put it into gear it drops to below 13 to around 12 and then slowly continues dropping. I've had the alternator tested at Kragen and it was good and I've replaced the battery. I've checked all the cables and am now in the process of replacing the engine ground. Anyone have any thoughts?
Very true...when i first start my car it reads way past 18v(kind of like the fuel gauge does when you fill your tank up)...you put a multimeter on it and it reads 14.6V...quick and easy way to find out if your really having an overall electrical or gauge problem
Alex Barnes
Jan 24, 2015 10:21 PM
edman
Jan 22, 2015 02:45 PM
