Engine toast, maybe? What to do next
Originally posted by Terran2k
whats your budget?? what happened to ur engine btw?
Originally posted by NXz28
fully forged 383, or 396...don't go n/a...add a blower or better yet if the budget allows a turbo setup.
you could probably get a cheap replaced motor locally at a junk yard for around $500. get it fully rebuild...machine shop fees around $300-$400. with new bearings (cam, main, rod)..... and then a new gasket set around $150. plus assembly $350...
while its out you could buy a cam, vavle springs, 1.6 rr's $580 from combo motorsports or a lot cheaper for the lt4 hot cam kit...
you could also get your heads p & p'd ...
Gtpguy
Jan 26, 2015 04:50 PM
JasonD
Aug 23, 2010 03:14 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
BAD00T/A
Jul 21, 2002 07:35 PM
