Shoebox need part #
Old Sep 5, 2004 | 11:40 PM
Loadre's Avatar
Shoebox need part #
Searched and all I could find was the part number for the hose. I need the pn for the plastic elbow that connect the PCV hose into the pass. side valve cover. Thanks a bunch.
Old Sep 5, 2004 | 11:53 PM
Spinner's Avatar
Re: Shoebox need part #
I believe your looking for GM part # 25095452
Old Sep 6, 2004 | 12:08 AM
Loadre's Avatar
Yup, that's it. Thanks.
Old Sep 6, 2004 | 09:34 AM
Lol, how do you know? I see it as 12550625. That other number is for the PCV valve that goes on the driver's side, into the intake. Don't you want the plastic elbow that goes into the RH valve cover?
I think the hose comes with the plastic elbow, but not positive.
Old Sep 6, 2004 | 09:40 AM
Loadre's Avatar
Put the number in on GMpartsdirect.com and it came up as a PCV valve or something similiar. I had already searched back in lots of posts and the part number he gave was not the part number everyone else gave for the valve that goes into the drivers side of the intake. So using simple reasoning since it was not the same part number and it said it was a PCV valve, I would hope it's the correct one. If not, it was only a couple bucks.
I looked back in the posts and several people said that the hose did not come with the elbow.
Old Sep 6, 2004 | 09:46 AM
Loadre's Avatar
n/m I'm a retard. I wrote down the PN for the metal tube on the drivers side and hose on the pass side. Guess I'll go back to gmpartsdirect and pay $10 for shipping on a $3 item.
Old Sep 6, 2004 | 02:02 PM
Mtrhds94Z's Avatar
Get this:
It'll replace the elbow with an oil seperator:
Deutsch Oil Seperater Breather BF412 [or Purolator part B23165 or Fram BA 6592]
Pep Boys, NAPA, etc..
And it helps that oil going to the TB prob a bit also..
Old Sep 6, 2004 | 07:15 PM
Spinner's Avatar
I see 336018 as the piece that screws into the intake.
25095452 is also delco # cv695c
Could be I'm also reading the parts manual diagram wrong.
EDIT: Yep, that was the case. Shoebox has the right parts #. Too many pcv parts, and didnt see that one.
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
