Engine stops after 7-8 seconds (short post pls help)
Old Jul 24, 2006 | 08:24 AM
JustNO's Avatar
New engine came with programmed OBD2, but its nor running more than 7-8 seconds. Code is P1626 D => Theft deterrent system fuel enable circuit.
The interesting thing is when I replace the stock PCM, it runs like a crap, but do not stop and there is no code.
any idea?
Old Jul 24, 2006 | 11:51 AM
JustNO's Avatar
Re: Engine stops after 7-8 seconds (short post pls help)
Pleaseee any opinion
Old Jul 24, 2006 | 12:30 PM
valter's Avatar
Disable VATS in PCM
Old Jul 24, 2006 | 12:40 PM
JustNO's Avatar
VATS ? Should I disable it ? And How? if thats the only problem it will be great.
Old Jul 24, 2006 | 12:58 PM
valter's Avatar
Guys, who programmed PCM for you should do it, give them a call. Probably, it can be bypassed in a hackish way, but my vote for fixing programming
Old Jul 24, 2006 | 01:00 PM
ulakovic22's Avatar
Yep, VATS. Thinks the car is stolen so it cuts fuel.
Old Jul 24, 2006 | 01:03 PM
Rising Phoenix's Avatar
In my friend's 95 Z28 the VATS relay burned out and the car wouldn't start at all... not exactly the same problem as what you're describing but it's obviously related. Maybe you could start there.
Old Jul 24, 2006 | 01:10 PM
JustNO's Avatar
OMG I can't send it back. I converted to OBD1 can I remove it by mailorder tune ??
And it can be fix with just a programming or should also do bypass ??
Old Jul 24, 2006 | 01:23 PM
valter's Avatar
sure and yes, if it's running with another PCM, programming will fix it.
Old Jul 25, 2006 | 09:29 AM
JustNO's Avatar
Just curious, why my engine runs with stock PCM, but die with programmed PCM ?? Okay its VATS, but why? Everything is the same.
Old Jul 25, 2006 | 11:18 AM
jonota's Avatar
Ignition turns with key, which attempts a start, but the PCM is looking for a different pellet value than what you have, so shuts off on theft deterent... my stab at it anyway. If it's the theft deterent shutting you down, as the code suggests, programming it out could fix it.
Jonota
Old Jul 25, 2006 | 11:22 AM
JustNO's Avatar
Thanks I got it now.
I did a big search. Some people say just programming is not enough, should also bypassing. Or only bypassing is not enough, should also programming. I'm confused. Probabily I will have to do 2 things together right?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Bearmans
Dec 3, 2014 05:28 AM
