Engine Squeak while giving it gas
Old May 26, 2006 | 01:42 AM
zachattack45's Avatar
Hey, I have a 95 Trans am LT1. When the car is in neutral there is no squeak, if i give it gas, it will squeak a little. Once i start driving it seems to be a constant squeak while i give it gas. It fades when I let off it. Sometimes it goes away and will come back if i go over a bump. Its very strange. Any ideas? The engine was just rebuilt about 5000 miles ago. Belt replaced 2000 miles ago
Old May 26, 2006 | 02:41 AM
Blown_Red_97z's Avatar
Re: Engine Squeak while giving it gas
might be the belt tensioner, i had this same squeek a while back. another one i had was when the water pump went out and was leaking... just 2 ideas for you, the belt tensioner is pretty cheap
Old May 26, 2006 | 02:43 AM
thanks for the ideas. Might be the tensioner. JUst replace the pump so i doubt its that.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
karnykamaro
Feb 2, 2015 01:37 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
simple
Aug 11, 2002 11:56 AM
