Engine Squeak while giving it gas
Hey, I have a 95 Trans am LT1. When the car is in neutral there is no squeak, if i give it gas, it will squeak a little. Once i start driving it seems to be a constant squeak while i give it gas. It fades when I let off it. Sometimes it goes away and will come back if i go over a bump. Its very strange. Any ideas? The engine was just rebuilt about 5000 miles ago. Belt replaced 2000 miles ago
Re: Engine Squeak while giving it gas
might be the belt tensioner, i had this same squeek a while back. another one i had was when the water pump went out and was leaking... just 2 ideas for you, the belt tensioner is pretty cheap
F'n1996Z28SS
Aug 23, 2023 11:19 PM
