engine running bad all of a sudden
Old Sep 19, 2008 | 11:55 PM
mean-greenz28's Avatar
i got a automatic 94 z28.
today i went to start it and it hesitated really bad then finally started up.
when i started driving, it was really rough, like it was having trouble accelerating and it just sounded rough. spark plugs? any suggestions would really be appreciated. thanks
Old Sep 20, 2008 | 12:02 AM
87bandit's Avatar
burnt wire, bad iginition coil, bad plugs, bad opti, bad maf, stuck injector, etc
the list goes on and on
scan it or start replacing cheap **** then go from there (i.e. - plugs)
Old Sep 20, 2008 | 07:47 AM
2000GTP's Avatar
Is there an SES light? Almost sounds like an engine misfire. As suggested, check over plugs and wires for starters. Also look for any obvious vacuum leaks.
Old Sep 20, 2008 | 09:10 AM
brand new ignition coil, new optispark, new wiring. but i just found out my radiator needs to be flushed, would that be the reason for the roughness? and my engine is ticking.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Ricardo
Nov 29, 2014 10:58 AM
Lions3
Apr 11, 2003 10:55 AM
