Engine rpm's jump when above 2500 rpm's
Old Aug 13, 2011 | 10:58 AM
camarorz28's Avatar
Hey guys my car started do something strange. While running smooth at low rmps under 2500 it's good. After 2500 i see rpm's needle jump up and Down and loose power then back to normal. In just this year I have replaced 2 ECM from autozone. Other than being bad ecm's could there be something taking out the ECM? I think the ECM is going out but I just change it about 4-5 months ago.
Old Aug 13, 2011 | 01:36 PM
Re: Engine rpm's jump when above 2500 rpm's
It appears you are saying the tach needle it jumping to indicate higher RPM, but the engine is not suddenly increasing speed to that RPM.
Could be the high resolution pulse signal from the optical cam position sensor in the Optispark distributor. Scan it for codes. If there's a problem, you will find DTC 36 or possibly DTC 16.
Why did you replace your PCM (93 was last year with ECM)? They seldom fail.
Old Aug 13, 2011 | 07:46 PM
Bersaglieri's Avatar
I had a similar problem and it ended up being the connector from the Optispark to the PCM, I.E. what Injuneer is saying.
-Dustin-
Old Aug 14, 2011 | 06:44 PM
camarorz28's Avatar
Sorry posted wrong info. I replaced the ICM not ECM. I did scan it but no codes came about. Yes correct tac needle jumps and when it does I feel a loose of power.
Old Aug 15, 2011 | 01:11 PM
boostedz28lt1's Avatar
Could it be the transmission slipping above 2500rpm? when i first got my z the tranny would bounce off the rev limiter over 3000k in any gear... Might not be the issue just throwing it out there....
Old Aug 16, 2011 | 01:07 AM
camarorz28's Avatar
Not tranny related.
Today while driving to work 5 minute drive car shut off twice. First it turn over but didn't start. Then start then die again then start. Checked for codes and nothing.
Old Aug 16, 2011 | 05:22 AM
How are you checking for codes?
Old Aug 16, 2011 | 11:33 AM
camarorz28's Avatar
I have the auto xray scanner. I've check for codes on it before I know it works.
Old Aug 16, 2011 | 12:23 PM
camarorz28's Avatar
So I check again with scanner hook up and I wiggle the harness attaching to ic
And car die. Unplugged it, plugged it back car starts. I check for codes and I get a 41 code electronic spark timing is open. I just touch the connector at ic
And car dies again.
Old Aug 16, 2011 | 01:44 PM
camarorz28's Avatar
As I wiggle the connector the car dies. Any idea how k can replace the connector it seems to not make a tight connection.
Old Aug 16, 2011 | 05:32 PM
Shoebox has the part number for the ICM "pigtail" that will replace the connector. Look at the list in the right hand column:
http://shbox.com/1/Parts.htm
Old Aug 17, 2011 | 11:00 AM
camarorz28's Avatar
thanks for the help. im going to try to order it at dealership hope that solves the problem because after a while it would make sense that it would start to loosen up and eventually loose enough to throw a 41 code spark timing ope
Injuneer i know you may not have all the answer to everyone's problem. but how would i go about switching the wires to the one i buy?
Old Aug 17, 2011 | 05:07 PM
Why are you buying it at a dealer? They will charge to 5X what it's worth.
Cut the old wires, strip and splice to the new wires. I prefer a soldered connection. Put a piece of heat shrink on each wire before your solder it, and slide the heat shrink up the wire away from the joint you are soldering. Wait for the joint to cool, slide the heat shrink over the joint and apply heat with a hair dryer or a heat gun. Make sure you spliced the wires in the exact sequence they were attached to the original harness connector.
Old Aug 18, 2011 | 12:25 PM
camarorz28's Avatar
well it looks like the connector i got from the dealer wont fit. the connector the car has is a square end connection. what i got from dealer is for a straight connecting. i didnt know where to buy so i went to dealer. autozone has it for 13. 67 but needs to be order.
D1SC383LT4
Jan 26, 2015 01:41 PM
edman
Jan 25, 2015 02:41 PM
97SSdude
Dec 31, 2014 07:43 PM
kev93z28
Aug 19, 2002 12:48 AM
centric
Aug 15, 2002 09:04 PM
