94 LT1 Air Pump Removal
Old Aug 16, 2011 | 08:25 PM
detroitlt1's Avatar
Jet hot long tubes are in, however my buddies dad left the air pump in and just cut the lines back and put caps on the lines running to the headers. The caps blew off now I have a ticking noise. I would like to remove the entire air pump assembly because I do not think capping it is a good idea. It will still be pumping.
So how do I attempt removing everything?
Will I need a different belt? what size will i need?
Old Aug 16, 2011 | 08:33 PM
RamAir95TA's Avatar
Re: 94 LT1 Air Pump Removal
There is nothing wrong with capping the ports on the headers just as long as you use a good plug.
The AIR pump is electric...it is not belt driven.
Removing everything is easy - just start removing stuff. There's at least a dozen threads on the subject so I'd start with a search.
Old Aug 16, 2011 | 08:38 PM
detroitlt1's Avatar
Ok I thought it was belt driven. Thats better it being electric.
Old Aug 16, 2011 | 08:40 PM
detroitlt1's Avatar
Also I am concernced because after the lt install with ORY Pipe I now throw service engine... Any ideas? It is a 94. He also replaced the 02 sensor and the oil sending unit was bad so he replaced that. Any ideas on the engine code?
Old Aug 16, 2011 | 11:47 PM
detroitlt1's Avatar
Code may be from egr being blocked off?
Still semi confused on the proper removal of this. I did a search and I am not clear on what to do with the vacuum lines.
What about the thick vaccum style line that runs to my cai?
Old Aug 17, 2011 | 10:51 AM
SlowMoComotion's Avatar
I just completed a removal of both the A.I.R and the EGR. I am assuming from your signature it is on a 94 lt1?
When you remove the A.I.R you have to cap off the line that runs to your cold air intake. You also have to cap off the headers. What I used to cap off my headers was a 1/2 " brass hex head plug. do a search on google and you can find a picture to see what one looks like. I also used some muffler cement to seal the plug and the prevent it from vibrating out. It comes in a tube and is heat activated. good to 1600 deg Fahrenheit.
I dont post much so I am not sure how to include a picture. here is a link http://imageshack.us/photo/my-images/192/img7111j.jpg/
Old Aug 17, 2011 | 11:04 AM
RamAir95TA's Avatar
Or just buy the right plug. M22 for OBDI cars, M18 for OBDII. Commonly found in most parts stores.
Old Aug 17, 2011 | 08:17 PM
detroitlt1's Avatar
Headers all in everythings good except they burnt threw a wire that rested on. So i have msds. any tricks to routing these wires? anyway to route around headers? tricks tips?
Old Aug 18, 2011 | 05:14 AM
My MSD's are routed from the bottom, but I don't run them off the Opti. Wires are 10 years old, and never had a burnt wire.
http://www.injuneer.com/images/photos/Engine/CoilsR.jpg
Old Aug 18, 2011 | 01:54 PM
detroitlt1's Avatar
I dont think mine can go like that because they are the precuts
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
CamaroZBoy
Aug 19, 2002 12:41 PM
