Engine Removal Guide
Old Feb 25, 2006 | 12:04 AM
  #16
SiDeWaYZz28's Avatar
Re: Engine Removal Guide
right on for the guide
Old Feb 25, 2006 | 11:59 AM
  #17
jtcz28's Avatar
How tall of a ceiling do you need to lift the car up??
-Justin
Old Feb 25, 2006 | 12:59 PM
  #18
Jeff95TA's Avatar
My garage ceiling is 8.5' high, the opener hangs down 1', and I wasn't that close to it, so.... 7' should work.
Old Feb 25, 2006 | 01:30 PM
  #19
jtcz28's Avatar
thanks...I believe mine is only 7.5 so i am going to check
-Justin
Old Mar 2, 2006 | 09:51 AM
  #20
All_Z_Way's Avatar
Nice write-up. I will be pulling an engine this weekend and this is a big help.
Old Mar 2, 2006 | 10:02 AM
  #21
sabre81's Avatar
Originally Posted by Jeff95TA
Here's an engine removal guide I put together. I might have done a few steps that didn't have to be done. Had to drop the picture quality so I could upload to my account. A few people have the good version floating around. First file is the pictures (11 MB), 2nd is the writeup.
Comments are welcome!
http://home.comcast.net/~saccani/Jef...l_Pictures.doc
http://home.comcast.net/~saccani/Jef...ne_Removal.doc
So how smooth was the removal process? Were there any points during the process where you wanted to beat your head against the wall?? What was the most difficult part?
Old Mar 2, 2006 | 11:06 AM
  #22
Jeff95TA's Avatar
No head beating moments. Being my first removal, just figuring out where to put jacks to pull it all out took a little time, since I was being a little cautious so nothing tipped. And researching how other people did it.
Hardest part was probably getting the brake lines loose from the ABS/TCS modules without rounding off the heads. Someone mentioned using short quick blows to the wrench instead of applying constant pressure and that worked pretty well to "crack" them loose.
I didn't have any rusted on bolts either so that made it easier.
Old Jun 26, 2016 | 08:43 PM
  #23
Jeff95TA's Avatar
Since Comcast was nice enough to not have storage space anymore, I finally rehosted the files. May be a bit obsolete at this point! Can't believe it's been 10 years.
Words:
https://drive.google.com/open?id=0B1...F9NdnZNS0U3M00
Pictures:
https://drive.google.com/open?id=0B1...zZ3RnQ3Q04yeGM
You have to open them in Word or they look weird.
PDF versions:
https://drive.google.com/open?id=0B1...TBFQlB6TE1YYWM
Old Jun 26, 2016 | 09:30 PM
  #24
LOL, at least you are still around (and kind enough) to rehost them.
Old Jun 26, 2016 | 09:33 PM
  #25
Thanks. Maybe time for a "sticky", if that's OK?
Maybe add a note that the Pictures file is 114 MB?
In the "PDF versions" appears to be the same photo file, one in Word and one as a .pdf?
Just trying to eliminate any confusion (which may be totally on my part - old age is a b!tch).
The edits in the original post do not seem to be working "Not Found Error 404"
Old Oct 18, 2017 | 12:38 AM
  #26
ACE1252's Avatar
I've still got them here(the doc versions)....at least I think they are the same documents.
Index of /LT1_Removal_From_Bottom
Old Jun 9, 2018 | 08:11 AM
  #27
KYWes's Avatar
I appreciate this write up. I've printed it and keep it handy though I don't have to refer to it anymore. Here's a tip that I did this last time that may help someone.
It's amazing how much quicker things go every time I do another engine/transmission pull.
It's always been "fun" getting the strut tower in place.
This time I took 3/8" bolts, one 4" and one 3 1/2", cut off the head and screwed them into the strut mounting plate.
This allowed me to align the strut into its holes as I raised the combo into position. The two lengths let me get one started and the shorter one allowed me to then finalize the adjustment as I raised it.
It made the re-install go a little quicker.
jclt12003
Dec 23, 2021 10:25 PM
camaroz99b
May 2, 2005 03:35 PM
Todd 2001SS
Jan 11, 2005 02:21 PM
ford
N2O Tech
Sep 6, 2004 10:45 PM
95z28 -quicksilver
Apr 23, 2004 05:36 PM
