Engine Removal
Old Jan 7, 2005 | 06:15 PM
ZX636RIDER03's Avatar
Engine Removal
I BELIEVE I JUST SPUN A MAIN BEARING SO I NEED TO PULL THE MOTOR OUT TO REPLACE IT. ANY ONE HAVE ANY SUGGESTIONS ON HOW TO DROP OR PULL AN LT1 OUT OF A 97 CAMARO??
Old Jan 7, 2005 | 06:19 PM
Crazy95Z's Avatar
Re: Engine Removal
Just start unbolting **** from the top and work your way down. Be sure to label everythign as you take it off though because when you're finished, it will be a bunch. You can either leave the tranny in or pull it out at the same time depending on what you decide. Just getting the front end off the ground on jackstands helps a lot, and to mention a good cherry picker. Good luck.
Old Jan 7, 2005 | 11:55 PM
y5e06's Avatar
Re: Engine Removal
I'd say drop it from the bottom. makes working on everything else a breeze. click on sig for '95 bird. I did it by myself w/o any help, very do-able
Old Jan 9, 2005 | 07:10 AM
Dave88LX's Avatar
Re: Engine Removal
Do a search on removing an engine out the bottom.
DirtyDaveW
Dec 1, 2016 05:37 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
centric
Aug 15, 2002 09:04 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
