Engine pull out the top w/o discharging a/c
Old Oct 19, 2003 | 11:12 PM
SC97TA's Avatar
Question Engine pull out the top w/o discharging a/c
Is it possible to pull the engine out the top without losing the a/c refrigerant? Has anybody done it? Did a search couldn't find any info.
If so what has to be striped off the front?
The transmission, clutch, and rad are removed.
I will be using the happy hooker from TPIS.
The car is a 1997 T/A.
Kris
Old Oct 25, 2003 | 12:29 PM
Lt1tko5o's Avatar
Yes, it can come out the top with out any problem. Remove the ac compressor from engine and tie it out of the way. I remove the balancer hub and water pump, and it lifts out fine, the radiator also has to be removed. Watch out for the engine hitting the AC condensor. Just be careful and it will come right out.
Brian
Old Oct 25, 2003 | 01:44 PM
Dave88LX's Avatar
Yup sure can! But it was a PITA!!!
http://paradox.shacknet.nu/dave88lx/...nock/pull2.jpg
In hindsight, I'm going to drop the K-Member, and put everything back up togother (engine, tranny, headers etc.)
Old Oct 25, 2003 | 07:07 PM
OneFlyn95z28's Avatar
I have done it 6-7 times.
Never a PITA.
Where dave made the mistake is he left the manifolds on. If you take them off(easy) you lift the motor and come forward then turn the motor 90* and pull the rest of the way out. I have yet to pull the hood off my car
Good luck man!
Old Oct 25, 2003 | 08:57 PM
gb95zconv's Avatar
Yep....not a problem...you can leave the ps pump hooked up too. Just unbolt everything and work the accessory bracket out. Tie the ac compressor and ps pump out of the way.
Old Oct 26, 2003 | 07:28 PM
SC97TA's Avatar
Thanx for the replies!
I ended up disconnecting the a/c condensor but left the ps pump hooked up.
Getting closer to pulling this thing lots of work, 1hr here 2hrs there!
Kris
calaban
May 18, 2020 06:43 PM
Gtpguy
Jan 26, 2015 04:50 PM
CaRParts102
Dec 6, 2014 08:45 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
