Engine pull - It's stuck!
Old Feb 5, 2006 | 11:25 AM
Radd's Avatar
Need help here if anyone has any advice i would appreciate it.
I have my motor disconnected from everything.
there is plenty of clearance around the motor the only thing in the way is the headers that i can not take out.
The motor will not come out. i have it on the cherry picker. the motor is about 1/2 in to 1 inch out from the tranny but won't go any more ive tried pushing it back in and pulling it out. i fought with it for about 3 hrs trying to pry it out.
im in desprate need of some advice
Joe
here are some quick pics incase a visial will help
http://radd.zeroproof.com/060205_123721.jpg
http://radd.zeroproof.com/060205_123750.jpg
http://radd.zeroproof.com/060205_123848.jpg
http://radd.zeroproof.com/060205_123857.jpg
http://radd.zeroproof.com/060205_123954.jpg
http://radd.zeroproof.com/060205_124007.jpg
http://radd.zeroproof.com/060205_124114.jpg
http://radd.zeroproof.com/060205_124128.jpg
http://radd.zeroproof.com/060205_124201.jpg
Old Feb 5, 2006 | 11:38 AM
roughneck427's Avatar
Re: Engine pull - B*tch is stuck!
is it a M6 if so you need to remove the slave cylinder and pull the clutch fork to disconnect it from the pressure plate
Old Feb 5, 2006 | 11:59 AM
FastZinTennessee's Avatar
Why can't you take the headers off? I think the headers are going to be the deal breaker here as to why the motor is stuck (hard to tell from the pictures though).
Old Feb 5, 2006 | 12:02 PM
Radd's Avatar
New pics
Yes its a M6 just pull the slave cylinder out? anything i need to know on doing it?
Old Feb 5, 2006 | 12:06 PM
Birdman7389's Avatar
Originally Posted by Radd
New pics
Nope, its just 2 nuts. Slide it off along with the spacer, reach in and pull the clutch fork straight back.
yeah take off the 2 nuts holding the slave cylinder on remove the aluminum piece that is sanwiched between the slave cylinder and the bellhousing im sure with the motor slightly out there is pressure against the fork so take you a good prybar and slip the fork out like you were gonna pull it through spot where the slave was attached
Edit: yeah what birdman said
Old Feb 5, 2006 | 05:55 PM
Radd's Avatar
i got it out but it was the slave cyclinder on the clutch that was holding it to the tranny. i took off the slave cyclinder and pulled the fork down and out went the engine.
took apart the bottom end and aparently the car had the oil level sensor replaced at one point in its life because the current one is intact but i found parts of the oil level sensor jammed into the oil pick up along with pieces of metal.
im guessing the oil pump went out when the connecting rods bearings started getting starved for oil and the oil pump picked up the metal which went into the pump because the screen was torn from the plastic part that was jammed into the oil screen.
so the oil pump jammed up and gave up and the rest of the connection rods bearings went to crap.
also something metal got into the #4 cyclinder because the piston and the head are beat to hell
New Question
Should i check and/or replace the new motors (62K) connecting rod sleeves/bearings(not sure which they are called)?
Also should i replace the oil pump.
i saw a melling oil pump that has 25% more volume and 25 psi more than factory pumps?
Old Feb 5, 2006 | 06:44 PM
May as well do a quick teardown and stock rebuild on the new(used motor). Wont cost too much, and you will know that it is good.
Old Feb 5, 2006 | 11:51 PM
Re: Engine pull - It's stuck!
PLEASE do not post oversize photos. Either resize them before you post them, or simply include the links.
Old Feb 6, 2006 | 12:42 AM
scottslt1z28's Avatar
people need to get better monitors if they cant see 1024x768 pictures easily on theirs.
1920x1200 owns all (except for anything larger)
Oh yeah..........GL man!!!
Old Feb 6, 2006 | 06:36 AM
If you'd like to argue with the Moderators, you're supposed to do it via PM, not by postnig in a thread.
Old Feb 6, 2006 | 01:42 PM
Radd's Avatar
I don't think he was arguing
i think he was just messing around / joking
atleast thats what i took from it.
i will make sure the size is right next time did not know
Old Feb 6, 2006 | 02:18 PM
1FstFormulaV8's Avatar
If you could have got the car on a lift it would have been much easier to just drop the engine and the K-Member. IMO.
transam_388
Mar 15, 2015 11:53 AM
cmdeshon
Dec 12, 2014 10:51 PM
tds1213
Nov 27, 2014 12:55 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
