Engine out the bottom pics...
Old Apr 1, 2006 | 11:32 PM
Javier97Z28's Avatar
Moderator
Just used FastZinTN's short writeup and it was right on the money Thanks man.
Here's some pics from today's adventure. We started mid afternoon and were done in the evening, no biggie really. Couldn't get it on the stand yet b/c I didn't have bolts to put it on with! doh! Tomorrow I'll pick some up.
The whole thing was really pretty easy, no need to use wood blocks or anything to get the car high enough, 6 ton jack stands are *plenty* tall enough to secure the car to get the engine out.
Uh, since we're on there, left to right:
Cmr0Z28, redemn93, me, and a friend of ours Chris... sponsored by Budweiser.
Old Apr 1, 2006 | 11:34 PM
FastZinTennessee's Avatar
Re: Engine out the bottom pics...
Glad to hear it went smoothly for you
Old Apr 1, 2006 | 11:40 PM
Dave89IROC's Avatar
you will love being able to fully assemble the engine that way, I did a few out/in the bottom, and I don't even take the wheels off, I just put blocks of wood between the LCA and the K-member, then lift the car, put a jack under the back of the trans, and roll it out
Old Apr 1, 2006 | 11:44 PM
Moderator
Yah I might roll it back in with the wheels this time, just need to get it a little higher to do that, but it would probably be easier than worrying about the assembly rolling off the jack
Old Apr 1, 2006 | 11:54 PM
Dave89IROC's Avatar
hardest thing is geting tools on the K-member bolts, and lining up the studs at the top of the shocks, but not too bad,
Old Apr 1, 2006 | 11:56 PM
redemn93's Avatar
things went pretty smoothly. for as much as we messed around, we made good time for first time effort. should be pretty quick if we'd ever needed to do it again. next time i think the wheels need to stay on imo. feel pretty accomplished with the progress we made.
Old Apr 3, 2006 | 07:55 AM
Moderator
ttt for the weekday crew
Old Apr 5, 2006 | 02:23 PM
marshall93z's Avatar
Did you use a chain or straps to hook to the hoist? I can't really see a good ploace to hook to the drivers side.
Old Apr 5, 2006 | 02:33 PM
T/A KID's Avatar
Boy I am glad I just put a lift in at my shop. lift the car up, un-bolt everything and the tranny and motor come out together. I would do it just for a head and cam install that easy
Old Apr 5, 2006 | 03:01 PM
ajschult's Avatar
You suck...
Old Apr 5, 2006 | 03:17 PM
cndctrdj's Avatar
thats awsome im glad you guys did it so easily
i need to buckle down and do the same thing
i just need a couple 30 racks and sme friends
Old Apr 5, 2006 | 09:50 PM
cehan's Avatar
When I did mine, I pulled the coolant overflow reservoir and the CAI. That leaves two large holes on each of the front frame horns that I rigged a heavy strap thru (you could use a chain) and hoisted the front of the car from the middle.
Old Apr 5, 2006 | 09:53 PM
Dave89IROC's Avatar
yup, works great
Old Apr 6, 2006 | 12:34 PM
That's what I ended up doing!
Old Apr 6, 2006 | 12:42 PM
Moderator
I used a 3300lb tow strap (rated to 10000 lbs break strenght) and wrapped it around the front frame of the car (it's the boxed frame in front of the radiator).
sscott
Jan 17, 2015 04:30 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
formula218
Dec 2, 2014 04:27 PM
Hoodshaker
Aug 27, 2002 02:32 PM
